A7S usb-c to hdmi issue
I’m running A7S on r6 cli image and t4 cli image.
After i configured wifi + imx214 camera on the r6 image, it worked for a while but i had to reboot it, it lost hdmi output. Board works fine, wifi, imx214, except HDMI output.
I left the board for a week in the drawer, next time i booted it, hdmi was there, fully working. Worked a few hours and, again, after a reboot, lost hdmi again. I can’t figure out what is the issue. I can only guess it enters standby, no idea really.
R6 CLI LOG:
[    0.541024] husb311 failed to find usb power
[    0.556282] husb311 14-004e: fail to register tcpci port, -517
[    2.977337] husb311 failed to find usb power
[    2.987088] husb311 14-004e: vbus is already Off
[    2.990135] husb311 14-004e: vbus is already Off
[    2.990169] husb311 14-004e: wakeup source is disabled!
[    2.990177] husb311 14-004e: Vendor ID:0x2e99, Product ID:0x0311, probe success
[    3.196579] husb311 14-004e: set vbus On
[    3.523017] husb311 14-004e: CC1: 0 - Open, CC2: 2 - Rd
[    3.631158] switcher 10.phy_switcher: conf:0x0 status:0x0 mode:0, set mux state STATE_USB → STATE_SAFE
[    4.035184] husb311 14-004e: CC1: 0 - Open, CC2: 2 - Rd
I installed the T4 CLI image, the Wi-Fi and imx214 camera work, and I have no issues with HDMI on the T4. I can reboot and shut down (forgiving reboot issue), and HDMI works every time.
T4 CLI LOG:
[    0.047701] [      T1] /soc@3000000/twi@7084000/husb311@4e: Fixed dependency cycle(s) with /soc@3000000/usbc2@12/xhci2-controller@6a00000
[    0.047771] [      T1] /soc@3000000/usbc2@12/xhci2-controller@6a00000: Fixed dependency cycle(s) with /soc@3000000/twi@7084000/husb311@4e
[    0.062311] [      T1] sunxi:pin:[INFO]: sunxi pinctrl version: 0.6.8
[    0.069786] [      T1] /soc@3000000/twi@7084000/husb311@4e: Fixed dependency cycle(s) with /soc@3000000/usbc2@12/xhci2-controller@6a00000
[    0.070947] [      T1] /soc@3000000/usbc2@12/xhci2-controller@6a00000: Fixed dependency cycle(s) with /soc@3000000/twi@7084000/husb311@4e
[    0.073851] [      T1] /soc@3000000/twi@7084000/husb311@4e/connector: Fixed dependency cycle(s) with /phy_switcher@10
[    0.073881] [      T1] /phy_switcher@10: Fixed dependency cycle(s) with /soc@3000000/twi@7084000/husb311@4e/connector
[    0.234314] [      T1] /soc@3000000/usbc2@12/xhci2-controller@6a00000: Fixed dependency cycle(s) with /soc@3000000/twi@7084000/husb311@4e
[    0.234348] [      T1] /soc@3000000/twi@7084000/husb311@4e: Fixed dependency cycle(s) with /soc@3000000/usbc2@12/xhci2-controller@6a00000
[    0.234401] [      T1] /soc@3000000/twi@7084000/husb311@4e/connector: Fixed dependency cycle(s) with /phy_switcher@10
[    1.602101] [      T1] /soc@3000000/twi@7084000/husb311@4e: Fixed dependency cycle(s) with /soc@3000000/usbc2@12/xhci2-controller@6a00000
[    1.602163] [      T1] /soc@3000000/usbc2@12/xhci2-controller@6a00000: Fixed dependency cycle(s) with /soc@3000000/twi@7084000/husb311@4e
[    1.657558] [      T1] sunxi:tcpci_husb311I2C functionality : OK…
[    1.657893] [      T1] sunxi:tcpci_husb311husb311 failed to find usb power
[    1.667573] [      T1] husb311 14-004e: sunxi:tcpci_husb311vbus is already Off
[    1.669526] [      T1] husb311 14-004e: sunxi:tcpci_husb311wakeup source is disabled!
[    1.669529] [      T1] husb311 14-004e: sunxi:tcpci_husb311Vendor ID:0x2e99, Product ID:0x0311, probe success
[    1.669539] [    T113] husb311 14-004e: sunxi:tcpci_husb311vbus is already Off
[    1.681311] [      T1] core: _opp_supported_by_regulators: OPP minuV: 0 maxuV: 0, not supported by regulator
[    1.683311] [      T1] npu[1][1] vipcore, platform driver device=0xffff0000c0d8d810
[    1.693112] [      T1] Key type .fscrypt registered
[    1.693115] [      T1] Key type fscrypt-provisioning registered
[    1.780575] [     T10] husb311 14-004e: sunxi:tcpci_husb311husb311_detect_call:639 CC1: 1 - Ra, CC2: 2 - Rd
[    1.882342] [    T113] husb311 14-004e: sunxi:tcpci_husb311set vbus On
[    1.984518] [     T10] husb311 14-004e: sunxi:tcpci_husb311husb311_detect_call:639 CC1: 0 - Open, CC2: 2 - Rd
[    2.180529] [     T10] husb311 14-004e: sunxi:tcpci_husb311CC1: 0 - Open, CC2: 2 - Rd
[    2.724503] [     T10] husb311 14-004e: sunxi:tcpci_husb311CC1: 0 - Open, CC2: 2 - Rd
Any idea how to fix it?
You might try disable the sleep function to see if that fix the problem.
Unfortunately it did not help. This is a CLI image:
sudo rsetup
[sudo] password for rock:
/usr/lib/rsetup/tui/hardware/hardware.sh: line 281: xrandr: command not found
Created symlink /etc/systemd/system/sleep.target → /dev/null.
Created symlink /etc/systemd/system/suspend.target → /dev/null.
Created symlink /etc/systemd/system/hibernate.target → /dev/null.
Created symlink /etc/systemd/system/hybrid-sleep.target → /dev/null.
Created symlink /etc/systemd/system/suspend-then-hibernate.target → /dev/null.
No such schema ?org.gnome.settings-daemon.plugins.power?
Sleep control applied: true
Reboot is recommended to ensure GNOME schema changes fully take effect.
I flashed a new SD card and grabbed the log, so you can analyze it:
1 - First boot with ethernet cable attached, HDMi works:
[    2.907216][  T104] sunxi:pcie-rc-6000000.pcie:[ERR]: Speed change timeout
[    2.935339][  T104] husb311 failed to find usb power
[    7.435756][  T350] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.448235][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.459871][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.471278][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.486877][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.499400][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.514646][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.525518][  T327] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    7.544971][  T327] debugfs: Directory ‘2535000.i2s3_plat’ with parent 'allw!
[    7.696371][  T349] sunxi:vin:[ERR]: failed to get vipp16 IRQ resource
[    7.713878][  T349] sunxi:vin:[ERR]: failed to get vipp17 IRQ resource
[    7.735329][  T349] sunxi:vin:[ERR]: fetch vind_mclkpin_vol from device_treed
[    7.744060][  T349] sunxi:vin:[ERR]: vin_pinpower_get_set: set vind_mclkpin !
[   10.170309][  T361] ieee80211 phy0:
[   10.170309][  T361] *******************************************************
[   10.170309][  T361] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
2- Reboot with ethernet cable attached, HDMI lost signal:
[    2.913680][    T9] sunxi:pcie-rc-6000000.pcie:[ERR]: Speed change timeout
[    2.952836][    T9] husb311 failed to find usb power
[    4.796748][  T287] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dad
[    4.811996][  T104] debugfs: Directory ‘2535000.i2s3_plat’ with parent 'allw!
[    4.948944][  T311] sunxi:vin:[ERR]: failed to get vipp16 IRQ resource
[    4.962267][  T311] sunxi:vin:[ERR]: failed to get vipp17 IRQ resource
[    4.993474][  T311] sunxi:vin:[ERR]: fetch vind_mclkpin_vol from device_treed
[    5.002203][  T311] sunxi:vin:[ERR]: vin_pinpower_get_set: set vind_mclkpin !
[    7.734783][  T312] ieee80211 phy0:
[    7.734783][  T312] *******************************************************
[    7.734783][  T312] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
I could notice that right after “husb311 failed”:
It takes extra ms doing something and HDMI gets signal.
On next reboot, it takes less time to return and HDMI loose signal.
It was just the first reboot! So i think it needs to wait a few more ms to do something or wait for something.
I bought another cable and an adapter, but it’s still the same.
I booted up without the cable and then plugged it into the USB-C port, same situation, no HDMI output.
[ 893.239447] switcher 10.phy_switcher: conf:0x0 status:0x0 mode:0, set mux state STATE_USB → STATE_SAFE
[ 893.247498] husb311 14-004e: CC1: 0 - Open, CC2: 2 - Rd
[ 893.307638] switcher 10.phy_switcher: conf:0x406 status:0xa mode:0, set mux state STATE_SAFE → STATE_SAFE
[ 893.332842] switcher 10.phy_switcher: conf:0x406 status:0xa mode:4, set mux state STATE_SAFE → STATE_DP_C
[ 893.760212] husb311 14-004e: CC1: 0 - Open, CC2: 2 - Rd
isn’t vbus On missing before or after STATE_SAFE? shouldn’t it be set?
Additional log with another 4K USB-C to HDMI cable (no adapter):
1- Disconnected the cable
2- I left it unplugged overnight.
3- Connected the cable, seems to have gone a bit far with more debug info for this cable, but no HDMI.
[  189.218845] dwmac-sunxi 4500000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[  189.218905] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  892.952190] switcher 10.phy_switcher: orientation:2, set sw conf UNKNOW → REVERSE
[  892.953269] husb311 14-004e: set vbus On
[14107.654786] switcher 10.phy_switcher: conf:0x0 status:0x0 mode:0, set mux state STATE_DP_C → STATE_SAFE
[14107.654957] ------------[ cut here ]------------
[14107.654961] refcount_t: underflow; use-after-free.
[14107.654992] WARNING: CPU: 7 PID: 139 at lib/refcount.c:28 refcount_warn_saturate+0xf4/0x144
[14107.655016] Modules linked in: rfcomm cmac algif_hash aes_generic ecb algif_skcipher af_alg bnep aic8800_fdrv(O) sha256_generic cfg80211 aic_btusb(O) bluetooth libaes vfat fat zstd zst4
[14107.655240] CPU: 7 PID: 139 Comm: 14-004e Tainted: G        W  O      5.15.147-21-a733 #21
[14107.655253] Hardware name: sun60iw2 (DT)
[14107.655258] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=–)
[14107.655270] pc : refcount_warn_saturate+0xf4/0x144
[14107.655280] lr : refcount_warn_saturate+0xf4/0x144
[14107.655289] sp : ffff80000a52bbb0
[14107.655294] x29: ffff80000a52bbb0 x28: ffff0000c3b14080 x27: ffff0000c3ac9b80
[14107.655310] x26: ffff8000087a87b4 x25: ffff80000908d008 x24: ffff80000908d008
[14107.655325] x23: ffff0000c3b15080 x22: 0000000000000000 x21: ffff0000cf79a400
[14107.655340] x20: ffff800008c25ef8 x19: ffff0000cf79a408 x18: 00000000fffffffb
[14107.655354] x17: 0000000000008098 x16: 00000000000084a0 x15: 463d444956530065
[14107.655369] x14: 0000000000000000 x13: 2e656572662d7265 x12: 7466612d65737520
[14107.655384] x11: 3b776f6c66726564 x10: ffff8000093dc248 x9 : ffff8000080fa2f0
[14107.655398] x8 : ffff800009384248 x7 : ffff8000093dc248 x6 : 0000000000000000
[14107.655413] x5 : ffff0000ff6cfa10 x4 : 0000000000000000 x3 : 0000000000000027
[14107.655427] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000c3ac9b80
[14107.655441] Call trace:
[14107.655446]  refcount_warn_saturate+0xf4/0x144
[14107.655456]  kobject_put+0xf0/0x100
[14107.655469]  put_device+0x1c/0x2c
[14107.655484]  typec_altmode_release+0x60/0x100
[14107.655500]  device_release+0x3c/0x9c
[14107.655514]  kobject_put+0xac/0x100
[14107.655524]  device_unregister+0x2c/0x3c
[14107.655539]  typec_unregister_altmode+0x38/0x50
[14107.655553]  tcpm_reset_port+0x90/0x200
[14107.655562]  tcpm_detach+0x74/0xa4
[14107.655570]  tcpm_state_machine_work+0x107c/0x2f3c
[14107.655581]  kthread_worker_fn+0xc4/0x29c
[14107.655592]  kthread+0x15c/0x170
[14107.655600]  ret_from_fork+0x10/0x20
[14107.655613] —[ end trace 64d3dc2557df486a ]—
[14107.655896] husb311 14-004e: set vbus Off
[14107.658456] switcher 10.phy_switcher: orientation:0, set sw conf REVERSE → UNKNOW
[14108.168836] husb311 14-004e: CC1: 0 - Open, CC2: 0 - Open
[63185.563639] dwmac-sunxi 4500000.ethernet eth0: Link is Down
[63186.072456] switcher 10.phy_switcher: orientation:1, set sw conf UNKNOW → NORMAL
[63186.073886] husb311 14-004e: set vbus On
[63186.377525] switcher 10.phy_switcher: conf:0x0 status:0x0 mode:0, set mux state STATE_SAFE → STATE_SAFE
[63186.393996] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[63186.448396] switcher 10.phy_switcher: conf:0x406 status:0xa mode:0, set mux state STATE_SAFE → STATE_SAFE
[63186.474746] switcher 10.phy_switcher: conf:0x406 status:0xa mode:4, set mux state STATE_SAFE → STATE_DP_C
[63186.906378] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[63187.788748] switcher 10.phy_switcher: conf:0x406 status:0x8a mode:4, set mux state STATE_DP_C → STATE_DP_C
[63187.788768] hotplug gpio for phy mux not config yet
[63187.833940] switcher 10.phy_switcher: conf:0x406 status:0x18a mode:4, set mux state STATE_DP_C → STATE_DP_C
[63187.869808] [drm] DP-1 connection detected
[63187.898777] [drm] DP-1: Configuration mode 1920x1080@60Hz
[63187.908751] Console: switching to colour frame buffer device 240x67
[63187.949187] [drm] sunxi_de_atomic_flush de 0 not enable, skip
[63187.949263] [drm] [SUNXI-CRTC]sunxi_crtc_atomic_enable
[63187.949276] [drm] sunxi_de_enable index 0
[63187.949357] [drm] sunxi_de_enable finish sw en=0
[63188.118192] sunxi:sunxidrm:[ERR]: [EDP_ERR]: swing voltage reach max level, training1(clock recovery training) fail!
[63188.134439] [drm] DP-1: Configuration complete
[63188.314535] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[63197.973965] switcher 10.phy_switcher: conf:0x406 status:0x18a mode:4, set mux state STATE_DP_C → STATE_DP_C
[63198.490543] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[63208.155864] switcher 10.phy_switcher: conf:0x406 status:0x18a mode:4, set mux state STATE_DP_C → STATE_DP_C
[63208.666671] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
cat /sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card*/card*-DP-1///*
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-DP-1/device’: Is a directory
On
������m�Z�3x�bu�UO꣠’PTq@�������@���:�q8-@X,E�"�8=S
�23MB35
�J# �e
:�q8-@X,E�"�q X,%�"rQ� n(U�"�
������� �->��"enabled
1920x1080
1920x1080
1920x1080
1920x1080
1680x1050
1400x1050
1600x900
1280x1024
1440x900
1920x540
1280x800
1280x720
1280x720
1280x720
1280x720
1024x768
800x600
720x576
720x480
720x480
720x480
720x480
640x480
640x480
640x480
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-DP-1/power’: Is a directory
connected
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-DP-1/subsystem’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-Writeback-1/device’: Is a directory
On
disabled
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-Writeback-1/power’: Is a directory
unknown
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/card0-Writeback-1/subsystem’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/driver’: Is a directory
(null)
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/drm’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/graphics’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/iommu’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/iommu_group’: Is a directory
of:Nsunxi-drmT(null)Callwinner,sunxi-drm
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/of_node’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/power’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/subsystem’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5000000.de’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5500000.vo0’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5510000.vo1’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5730000.tcon3’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5731000.tcon4’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/device/supplier:platform:5740000.edp0’: Is a directory
DRIVER=sunxi-drm
OF_NAME=sunxi-drm
OF_FULLNAME=/soc@3000000/sunxi-drm
OF_COMPATIBLE_0=allwinner,sunxi-drm
OF_COMPATIBLE_N=1
MODALIAS=of:Nsunxi-drmT(null)Callwinner,sunxi-drm
disabled
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/power/autosuspend_delay_ms’: Input/output error
auto
0
0
disabled
unsupported
0
0
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/subsystem/card0’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/subsystem/card0-DP-1’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/subsystem/card0-Writeback-1’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/subsystem/card1’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/device/subsystem/renderD128’: Is a directory
drm 1.1.0 20060810
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0/card0-DP-1’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0/card0-Writeback-1’: Is a directory
226:0
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0/device’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-DP-1/device’: Is a directory
On
������m�Z�3x�bu�UO�’PTq@�������@���:�q8-@X,E�"�8=S
�23MB35
�J# �e
Њ �->��"enabled
1920x1080
1920x1080
1920x1080
1920x1080
1680x1050
1400x1050
1600x900
1280x1024
1440x900
1920x540
1280x800
1280x720
1280x720
1280x720
1280x720
1024x768
800x600
720x576
720x480
720x480
720x480
720x480
640x480
640x480
640x480
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-DP-1/power’: Is a directory
connected
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-DP-1/subsystem’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0/power’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0/subsystem’: Is a directory
MAJOR=226
MINOR=0
DEVNAME=dri/card0
DEVTYPE=drm_minor
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-Writeback-1/device’: Is a directory
On
disabled
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-Writeback-1/power’: Is a directory
unknown
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card0-Writeback-1/subsystem’: Is a directory
226:1
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card1/device’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card1/power’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/card1/subsystem’: Is a directory
MAJOR=226
MINOR=1
DEVNAME=dri/card1
DEVTYPE=drm_minor
226:128
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/renderD128/device’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/renderD128/power’: Is a directory
cat: ‘/sys/devices/platform/soc@3000000/soc@3000000:sunxi-drm/drm/card0/card0-DP-1/subsystem/renderD128/subsystem’: Is a directory
MAJOR=226
MINOR=128
DEVNAME=dri/renderD128
DEVTYPE=drm_minor
lshw
radxa-cubie-a7s
description: Computer
product: sun60iw2
width: 64 bits
capabilities: smp tagged_addr_disabled
*-core
description: Motherboard
physical id: 0
*-cpu:0
description: CPU
product: cpu
physical id: 1
bus info: cpu@0
capacity: 1794MHz
capabilities: fp asimd aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp cpufreq
*-cpu:1
description: CPU
product: cpu
physical id: 2
bus info: cpu@1
capacity: 1794MHz
*-cpu:2
description: CPU
product: cpu
physical id: 3
bus info: cpu@2
capacity: 1794MHz
*-cpu:3
description: CPU
product: cpu
physical id: 4
bus info: cpu@3
capacity: 1794MHz
*-cpu:4
description: CPU
product: cpu
physical id: 5
bus info: cpu@4
capacity: 1794MHz
*-cpu:5
description: CPU
product: cpu
physical id: 6
bus info: cpu@5
capacity: 1794MHz
*-cpu:6
description: CPU
product: cpu
physical id: 7
bus info: cpu@6
capacity: 2002MHz
*-cpu:7
description: CPU
product: cpu
physical id: 8
bus info: cpu@7
capacity: 2002MHz
*-cpu:8 DISABLED
description: CPU
product: cpu-map
physical id: 9
bus info: cpu@8
*-cpu:9 DISABLED
description: CPU
product: idle-states
physical id: a
bus info: cpu@9
*-memory
description: System memory
physical id: b
*-pci
description: PCI bridge
physical id: 0
bus info: pci@0000:00:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress vpd normal_decode bus_master cap_list
resources: memory:22000000-220fffff memory:22100000-2210ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.15.147-21-a733 xhci-hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.15
capabilities: usb-2.00
configuration: driver=hub slots=1 speed=480Mbit/s
*-usbhost:1
physical id: 2
bus info: usb@2
logical name: usb2
version: 5.15
capabilities: usb-3.10
configuration: driver=hub slots=1 speed=10000Mbit/s
*-usbhost:2
product: EHCI Host Controller
vendor: Linux 5.15.147-21-a733 ehci_hcd
physical id: 3
bus info: usb@3
logical name: usb3
version: 5.15
*-usb
description: USB hub
product: USB HUB
vendor: QinHeng Electronics
physical id: 1
bus info: usb@3:1
version: 13.20
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
description: Bluetooth wireless interface
product: AIC 8800D80
vendor: AICSemi
physical id: 1
bus info: usb@3:1.1
version: 1.00
serial: 20220103
capabilities: usb-2.00 bluetooth
configuration: driver=aic8800_fdrv maxpower=500mA speed=480Mbit/s
*-usb:1
product: USB2.0 Hub
vendor: Genesys Logic, Inc.
physical id: 2
bus info: usb@3:1.2
version: 9.01
*-usb:0
description: Keyboard
product: USB Keyboard
vendor: SEMICO
physical id: 1
bus info: usb@3:1.2.1
version: 1.10
capabilities: usb-1.10
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:1
description: Mouse
product: USB OPTICAL MOUSE
physical id: 4
bus info: usb@3:1.2.4
version: 1.00
*-usbhost:3
product: OHCI Host Controller
vendor: Linux 5.15.147-21-a733 ohci_hcd
physical id: 4
bus info: usb@4
logical name: usb4
version: 5.15
configuration: driver=hub slots=1 speed=12Mbit/s
*-network:0
description: Ethernet interface
physical id: 5
logical name: eth0
serial: 08:51:49:dc:f6:6c
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=Jan_2016 duplex=full ip=192.168.254.185 link=yes multicast=yes port=twisted pair speed=1Gbit/s
*-network:1
description: Wireless interface
physical id: 6
logical name: wlan0
serial: 9c:04:b6:9d:44:30
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=usb driverversion=5.15.147-21-a733 multicast=yes wireless=IEEE 802.11
root@radxa-cubie-a7s:/home/rock# get-edid | parse-edid
This is read-edid version 3.0.2. Prepare for some fun.
Attempting to use i2c interface
Problem requesting slave address: Device or resource busy
Looks like no busses have an EDID. Sorry!
I’m sorry nothing was successful. Maybe try some other arguments
if you played with them, or send an email to Matthew Kern [email protected].
Partial Read… Try again
edid decode (LG display):
edid-decode (hex):
00 ff ff ff ff ff ff 00 1e 6d 96 5a 01 01 01 01
03 1a 01 03 80 33 1d 78 ea 62 75 a3 55 4f a0 27
12 50 54 21 08 00 71 40 81 c0 81 00 81 80 95 00
90 40 a9 c0 b3 00 02 3a 80 18 71 38 2d 40 58 2c
45 00 fe 22 11 00 00 1e 00 00 00 fd 00 38 3d 1e
53 0f 00 0a 20 20 20 20 20 20 00 00 00 fc 00 32
33 4d 42 33 35 0a 20 20 20 20 20 20 00 00 00 ff
00 0a 20 20 20 20 20 20 20 20 20 20 20 20 01 11
02 03 1d f1 4a 04 04 03 01 04 12 04 1f 10 13 23
09 07 07 83 01 00 00 65 03 0c 00 10 00 02 3a 80
18 71 38 2d 40 58 2c 45 00 fe 22 11 00 00 1e 01
1d 80 18 71 1c 16 20 58 2c 25 00 fe 22 11 00 00
1e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 fe 22 11
00 00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 fe
22 11 00 00 18 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: GSM
Model: 23190
Serial Number: 16843009
Made in: week 3 of 2016
Basic Display Parameters & Features:
Digital display
Maximum image size: 51 cm x 29 cm
Gamma: 2.20
DPMS levels: Standby Suspend Off
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red  : 0.6376, 0.3339
Green: 0.3085, 0.6269
Blue : 0.1533, 0.0732
White: 0.3134, 0.3291
Established Timings I & II:
DMT 0x04:   640x480    59.940 Hz   4:3    31.469 kHz  25.175 MHz
DMT 0x09:   800x600    60.317 Hz   4:3    37.879 kHz  40.000 MHz
DMT 0x10:  1024x768    60.004 Hz   4:3    48.363 kHz  65.000 MHz
Standard Timings:
GTF     :  1152x864    60.000 Hz   4:3    53.700 kHz  81.624 MHz
DMT 0x55:  1280x720    60.000 Hz  16:9    45.000 kHz  74.250 MHz
DMT 0x1c:  1280x800    59.810 Hz  16:10   49.702 kHz  83.500 MHz
DMT 0x23:  1280x1024   60.020 Hz   5:4    63.981 kHz 108.000 MHz
DMT 0x2f:  1440x900    59.887 Hz  16:10   55.935 kHz 106.500 MHz
DMT 0x2a:  1400x1050   59.978 Hz   4:3    65.317 kHz 121.750 MHz
DMT 0x53:  1600x900    60.000 Hz  16:9    60.000 kHz 108.000 MHz (RB)
DMT 0x3a:  1680x1050   59.954 Hz  16:10   65.290 kHz 146.250 MHz
Detailed Timing Descriptors:
DTD 1:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz (510 mm x 290 mm)
Hfront   88 Hsync  44 Hback 148 Hpol P
Vfront    4 Vsync   5 Vback  36 Vpol P
Display Range Limits:
Monitor ranges (GTF): 56-61 Hz V, 30-83 kHz H, max dotclock 150 MHz
Display Product Name: ‘23MB35’
Display Product Serial Number: ‘’
Extension blocks: 1
Checksum: 0x11
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC   4:  1280x720    60.000 Hz  16:9    45.000 kHz  74.250 MHz
VIC   3:   720x480    59.940 Hz  16:9    31.469 kHz  27.000 MHz
VIC   1:   640x480    59.940 Hz   4:3    31.469 kHz  25.175 MHz
VIC  18:   720x576    50.000 Hz  16:9    31.250 kHz  27.000 MHz
VIC  31:  1920x1080   50.000 Hz  16:9    56.250 kHz 148.500 MHz
VIC  16:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz
VIC  19:  1280x720    50.000 Hz  16:9    37.500 kHz  74.250 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
DTD 2:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz (510 mm x 290 mm)
DTD 3:  1920x540    60.053 Hz  32:9    33.750 kHz  74.250 MHz (510 mm x 290 mm)
Vfront    2 Vsync   5 Vback  15 Vpol P
DTD 4:  1280x720    60.000 Hz  16:9    45.000 kHz  74.250 MHz (510 mm x 290 mm)
Hfront  110 Hsync  40 Hback 220 Hpol P
Vfront    5 Vsync   5 Vback  20 Vpol P
DTD 5:   720x480    59.940 Hz   3:2    31.469 kHz  27.000 MHz (510 mm x 290 mm)
Hfront   16 Hsync  62 Hback  60 Hpol N
Vfront    9 Vsync   6 Vback  30 Vpol N
Checksum: 0x03
Tested with SAMSUNG display now, same situation but different message:
[    2.923625][    T9] sunxi:pcie-rc-6000000.pcie:[ERR]: Speed change timeout
[    2.956215][    T9] husb311 failed to find usb power
[    4.139097][  T136] sunxi:sunxidrm:[ERR]: [EDP_ERR]: EQ training result: lane0:FAIL lane1:FAIL lane2:PASS lane3:PASS align:FAIL
[    4.152135][  T136] sunxi:sunxidrm:[ERR]: [EDP_ERR]: retry 5 times but still fail, training2(equalization training) fail!
[    4.999489][  T276] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed
[    5.010573][    T9] sunxi:sound-mach:[ERR]: 535 simple_parse_of(): simple_dai_link_of failed
[    5.027073][    T9] debugfs: Directory ‘2535000.i2s3_plat’ with parent ‘allwinner-edp’ already present!
[    5.196320][  T285] sunxi:vin:[ERR]: failed to get vipp16 IRQ resource
[    5.210947][  T285] sunxi:vin:[ERR]: failed to get vipp17 IRQ resource
[    5.225508][  T285] sunxi:vin:[ERR]: fetch vind_mclkpin_vol from device_tree failed
[    5.234373][  T285] sunxi:vin:[ERR]: vin_pinpower_get_set: set vind_mclkpin error, fail to set regulator voltage!
[    7.794142][  T295] ieee80211 phy0:
[    7.794142][  T295] *******************************************************
[    7.794142][  T295] ** CAUTION: USING PERMISSIVE CUSTOM REGULATORY RULES **
Do you need to use the R6 image? I saw you mentioned that the T4 CLI has no issues. Currently, the main development work may be on Debian 13 + Linux 6.6, which corresponds to later T4 versions. Are you saying the T4 CLI works normally for you?
Regarding USB-C to HDMI, yes.
T4 CLI has issues with shutdown and reboot (A7S), and i can’t access fb0 (/dev/fb0) and kmssink and glimagesink does not work (or there is no support for it?)
The T4 CLI is not suitable for production in its current state.
You’re using a Type-C to HDMI hub, right? Also, the R6 CLI version might not support hot-plug — you need to connect the display device before booting. The T4’s subsequent version will optimize display failure and reboot failure issues.
Thanks for your reply.
No. I’m using type-c to hdmi cable (tested two different cables, HD and 4K) and an adapter that you connect a hdmi cable to it. No hub.
I have the display connected before booting, but tested if hot-plug would work, but no.
Maybe i wasn’t clear, on the first boot with display connected i have hdmi output, after the boot with the display connected (and working) i ran rsetup to configure wifi using the display not the serial debugger.
After wifi configured i issued a “sudo reboot” (with display connected) and at this time hdmi is lost.
I can live without hdmi output but i usually don’t cross compile. Waiting for your T5 version.
I copied the sun60i-a733-cubie-a7s.dtb from img over the current one and rebooted. HDMI output is back.
So the problem is the new sun60i-a733-cubie-a7s.dtb after update.
No HDMI
-rwxr-xr-x 1 root root 194259 Apr 30 11:19 /usr/lib/linux-image-5.15.147-21-a733/allwinner/sun60i-a733-cubie-a7s.dtb
With HDMI output:
-rwxr-xr-x 1 root root 194259 Apr 30 08:19 /usr/lib/linux-image-5.15.147-21-a733/allwinner/sun60i-a733-cubie-a7s.dtb
rock@radxa-cubie-a7s:~$ sudo dmesg|grep -i hdmi
rock@radxa-cubie-a7s:~$ sudo dmesg|grep -i edp
[ 0.061878] platform 5740000.edp0: Fixing up cyclic dependency with 5731000.tcon4
[ 0.750446] drm_edp 5740000.edp0: supply vdd-edp not found, using dummy regulator
[ 0.750546] drm_edp 5740000.edp0: supply vcc-edp not found, using dummy regulator
[ 0.750675] [drm] edp’s combo-phy not setting, maybe not used!
[ 0.793767] sunxi-drm soc@3000000:sunxi-drm: bound 5740000.edp0 (ops sunxi_drm_edp_component_ops)
[ 5.905958] debugfs: Directory ‘2535000.i2s3_plat’ with parent ‘allwinner-edp’ already present!
rock@radxa-cubie-a7s:~$ sudo dmesg|grep -i 311
[ 0.131197] axp8191-aldo6: supplied by regulator-dummy
[ 0.517702] husb311 failed to find usb power
[ 0.533024] husb311 14-004e: fail to register tcpci port, -517
[ 2.967407] husb311 failed to find usb power
[ 2.976997] husb311 14-004e: vbus is already Off
[ 2.979850] husb311 14-004e: vbus is already Off
[ 2.979893] husb311 14-004e: wakeup source is disabled!
[ 2.979902] husb311 14-004e: Vendor ID:0x2e99, Product ID:0x0311, probe success
[ 3.186563] husb311 14-004e: set vbus On
[ 3.487054] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[ 4.003162] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[ 5.407295] husb311 14-004e: CC1: 2 - Rd, CC2: 0 - Open
[ 6.016311] aicbt_patch_table_load bt btport[4]:1
[ 6.287311] app_cmp
[ 6.304311] app_cmp
Update: Please disregard.
I decompiled the dtb and they have the same content. Copied back the updated dtb and hdmi output is still working after several reboots and shutdowns.
[ 0.065897] platform 5740000.edp0: Fixing up cyclic dependency with 5731000.tcon4
[ 0.745746] drm_edp 5740000.edp0: supply vdd-edp not found, using dummy regulator
[ 0.747053] drm_edp 5740000.edp0: supply vcc-edp not found, using dummy regulator
[ 0.747203] [drm] edp’s combo-phy not setting, maybe not used!
[ 0.792833] sunxi-drm soc@3000000:sunxi-drm: bound 5740000.edp0 (ops sunxi_drm_edp_component_ops)
[ 4.877202] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux reply timeout!
[ 4.968907] sunxi:sunxidrm:[ERR]: [EDP_ERR]: trilinear_aux_i2c_read retry 7 timies but still I2C_AUX_DEFER, request(i2c_addr:0x50 addr:0x50 len:16)
[ 5.030711] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.042007] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.053252] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.064546] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.075907] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.087089] sunxi:sunxidrm:[ERR]: [EDP_ERR]: edp wait aux retry timeout!
[ 5.095968] sunxi:sunxidrm:[ERR]: [EDP_ERR]: trilinear_aux_i2c_read retry 7 timies but still AUX_TIMEOUT, request(i2c_addr:0x50 addr:0xd0 len:16)
[ 5.226442] debugfs: Directory ‘2535000.i2s3_plat’ with parent ‘allwinner-edp’ already present!
