@Stephen
No matter what USB-C PD i use, it always uses the lowest 5V.
Tested with usb-c 12v (radxa), 33W (xiaomi), 65W (radxa)
Can you advise or suggest a fix to set it to 9V, and 3A?
tcpm_source_psy_4_0022-i2c-4-22
Adapter: rk3x-i2c
in0: 5.00 V (min = +5.00 V, max = +5.00 V)
curr1: 0.00 A (max = +0.00 A)
Current dts
usb_con: connector {
compatible = "usb-c-connector";
label = "USB-C";
data-role = "dual";
power-role = "sink";
try-power-role = "sink";
op-sink-microwatt = <1000000>;
sink-pdos =
<PDO_FIXED(5000, 3000, PDO_FIXED_USB_COMM)
PDO_FIXED(9000, 3000, PDO_FIXED_USB_COMM)
PDO_FIXED(12000, 1500, PDO_FIXED_USB_COMM)>;
I tried this (without success):
<PDO_FIXED(9000, 3000, PDO_FIXED_USB_COMM)
fusb302-4-0022
[ 1.250401] sw reset
[ 1.254214] fusb302 device ID: 0x91
[ 1.258934] pd := off
[ 1.258939] vbus is already Off
[ 1.258942] charge is already Off
[ 1.258946] vconn is already Off
[ 1.259793] pd header := Sink, Device
[ 1.259819] cc1=Open, cc2=Open
[ 1.264443] start drp toggling
[ 1.266424] IRQ: 0x80, a: 0x00, b: 0x00, status0: 0x83
[ 1.266427] IRQ: VBUS_OK, vbus=On
[ 1.273668] IRQ: 0x01, a: 0x40, b: 0x00, status0: 0x81
[ 1.273670] IRQ: TOGDONE
[ 1.279521] detected cc1=Open, cc2=Rp-def
[ 1.279527] cc1=Open, cc2=Rp-def
[ 1.480440] pd header := Sink, Device
[ 1.480471] vbus is already Off
[ 1.485317] pd := on
[ 1.797618] sending PD message header: 8d
[ 1.797630] sending PD message len: 0
[ 1.799839] IRQ: 0x41, a: 0x00, b: 0x00, status0: 0x81
[ 1.799851] IRQ: BC_LVL, handler pending
[ 1.802203] IRQ: 0x41, a: 0x00, b: 0x00, status0: 0x80
[ 1.802215] IRQ: BC_LVL, handler pending
[ 1.804231] IRQ: 0x41, a: 0x00, b: 0x00, status0: 0x81
[ 1.804249] IRQ: BC_LVL, handler pending
[ 1.806272] IRQ: 0x00, a: 0x10, b: 0x00, status0: 0x81
[ 1.806289] IRQ: PD retry failed
[ 1.809350] IRQ: 0x41, a: 0x08, b: 0x00, status0: 0x81
[ 1.809357] IRQ: BC_LVL, handler pending
[ 1.809362] IRQ: PD hardreset sent
[ 1.815404] pd := off
[ 1.815428] vconn is already Off
[ 1.843948] BC_LVL handler, status0=0x81
[ 2.193112] pd header := Sink, Device
[ 2.844004] pd header := Sink, Device
[ 2.848723] pd := on
[ 3.161513] IRQ: 0x41, a: 0x08, b: 0x00, status0: 0x81
[ 3.161516] IRQ: BC_LVL, handler pending
[ 3.161518] IRQ: PD hardreset sent
[ 3.166887] pd := off
[ 3.166893] vconn is already Off
[ 3.167694] pd header := Sink, Device
[ 3.197033] BC_LVL handler, status0=0x81
[ 3.818593] pd header := Sink, Device
[ 3.823366] pd := on
tcpm-4-0022
[ 1.250117] Setting usb_comm capable false
[ 1.254732] Setting voltage/current limit 0 mV 0 mA
[ 1.254737] polarity 0
[ 1.254753] Requesting mux state 0, usb-role 0, orientation 0
[ 1.255550] state change INVALID_STATE → SNK_UNATTACHED [rev1 NONE_AMS]
[ 1.255575] CC1: 0 → 0, CC2: 0 → 0 [state SNK_UNATTACHED, polarity 0, disconnected]
[ 1.255583] Start toggling
[ 1.275405] CC1: 0 → 0, CC2: 0 → 3 [state TOGGLING, polarity 0, connected]
[ 1.275409] state change TOGGLING → SNK_ATTACH_WAIT [rev1 NONE_AMS]
[ 1.275413] pending state change SNK_ATTACH_WAIT → SNK_DEBOUNCED @ 200 ms [rev1 NONE_AMS]
[ 1.475460] state change SNK_ATTACH_WAIT → SNK_DEBOUNCED [delayed 200 ms]
[ 1.475472] state change SNK_DEBOUNCED → SNK_ATTACHED [rev1 NONE_AMS]
[ 1.475478] polarity 1
[ 1.475483] Requesting mux state 1, usb-role 2, orientation 2
[ 1.476332] state change SNK_ATTACHED → SNK_STARTUP [rev1 NONE_AMS]
[ 1.476338] state change SNK_STARTUP → SNK_DISCOVERY [rev3 NONE_AMS]
[ 1.476343] Setting voltage/current limit 5000 mV 0 mA
[ 1.476352] vbus=0 charge:=1
[ 1.476360] state change SNK_DISCOVERY → SNK_WAIT_CAPABILITIES [rev3 NONE_AMS]
[ 1.481093] pending state change SNK_WAIT_CAPABILITIES → SNK_SOFT_RESET @ 310 ms [rev3 NONE_AMS]
[ 1.791114] state change SNK_WAIT_CAPABILITIES → SNK_SOFT_RESET [delayed 310 ms]
[ 1.791120] AMS SOFT_RESET_AMS start
[ 1.791123] state change SNK_SOFT_RESET → AMS_START [rev3 SOFT_RESET_AMS]
[ 1.791125] state change AMS_START → SOFT_RESET_SEND [rev3 SOFT_RESET_AMS]
[ 1.791127] PD TX, header: 0x8d
[ 1.800590] PD TX complete, status: 2
[ 1.800602] state change SOFT_RESET_SEND → HARD_RESET_SEND [rev3 SOFT_RESET_AMS]
[ 1.800608] AMS SOFT_RESET_AMS finished
[ 1.800609] AMS HARD_RESET start
[ 1.800611] PD TX, type: 0x5
[ 1.804066] PD TX complete, status: 0
[ 1.804073] state change HARD_RESET_SEND → HARD_RESET_START [rev3 HARD_RESET]
[ 1.808633] state change HARD_RESET_START → SNK_HARD_RESET_SINK_OFF [rev3 HARD_RESET]
[ 1.808636] vconn:=0
[ 1.808640] Requesting mux state 1, usb-role 2, orientation 2
[ 2.183633] pending state change SNK_HARD_RESET_SINK_OFF → SNK_HARD_RESET_SINK_ON @ 650 ms [rev3 HARD_RESET]
[ 2.833667] state change SNK_HARD_RESET_SINK_OFF → SNK_HARD_RESET_SINK_ON [delayed 650 ms]
[ 2.833677] AMS HARD_RESET finished
[ 2.834499] state change SNK_HARD_RESET_SINK_ON → SNK_STARTUP [rev3 NONE_AMS]
[ 2.834504] state change SNK_STARTUP → SNK_DISCOVERY [rev3 NONE_AMS]
[ 2.834507] Setting voltage/current limit 5000 mV 0 mA
[ 2.834516] state change SNK_DISCOVERY → SNK_WAIT_CAPABILITIES [rev3 NONE_AMS]
[ 2.839146] pending state change SNK_WAIT_CAPABILITIES → HARD_RESET_SEND @ 310 ms [rev3 NONE_AMS]
[ 3.149169] state change SNK_WAIT_CAPABILITIES → HARD_RESET_SEND [delayed 310 ms]
[ 3.149173] AMS HARD_RESET start
[ 3.149175] PD TX, type: 0x5
[ 3.152765] PD TX complete, status: 0
[ 3.152778] state change HARD_RESET_SEND → HARD_RESET_START [rev3 HARD_RESET]
[ 3.157419] state change HARD_RESET_START → SNK_HARD_RESET_SINK_OFF [rev3 HARD_RESET]
[ 3.157422] vconn:=0
[ 3.157425] Requesting mux state 1, usb-role 2, orientation 2
[ 3.158232] pending state change SNK_HARD_RESET_SINK_OFF → SNK_HARD_RESET_SINK_ON @ 650 ms [rev3 HARD_RESET]
[ 3.808432] state change SNK_HARD_RESET_SINK_OFF → SNK_HARD_RESET_SINK_ON [delayed 650 ms]
[ 3.808447] AMS HARD_RESET finished
[ 3.809316] state change SNK_HARD_RESET_SINK_ON → SNK_STARTUP [rev3 NONE_AMS]
[ 3.809325] state change SNK_STARTUP → SNK_DISCOVERY [rev3 NONE_AMS]
[ 3.809331] Setting voltage/current limit 5000 mV 0 mA
[ 3.809351] state change SNK_DISCOVERY → SNK_WAIT_CAPABILITIES [rev3 NONE_AMS]
[ 3.814583] pending state change SNK_WAIT_CAPABILITIES → SNK_READY @ 310 ms [rev3 NONE_AMS]
[ 4.124805] state change SNK_WAIT_CAPABILITIES → SNK_READY [delayed 310 ms]
