Hello, I would like to try using 64KB page size for performance reasons. However, if I enable them at the kernel (cix 6.10 acpi) configuration, my kernel panics during boot. Does a specific device rely on 4K pages, is it a kernel/driver bug or something completely different? As a side note, why does the board reset on a kernel panic, instead of hanging? As another side note, 64KB pages work on my Rock 5B and produce some nice performance improvement.
I built 6.16.0 & 6.16.3 kernels with 64k pages (+5.7% performance over 16k pages, and the improvement from 4k to 16k is the larger increase!) and had no problems.
(Although the low-level driver support is currently barely there in mainline kernels, sadly)
Thanks for your response,
I was using the cix kernel (version 6.6.10) because of the lack of drivers. Does the mainline kernel support the pcie (and the nvme slot), the UART and the ethernet? I need them for basic testing. Also, are you using a specific .config and boot command parameters? Finally, how did you measure the performance?
Thanks in advance
The mainline kernel supports all these things as long as you boot in ACPI mode - refer to this page for more details.
Yup, ACPI is needed for PCIe to work it turns out (for an LSI HBA in any case), and the other mentioned hardware does work. Many other lower-level devices plus NPU, GPU, etc. are not supported, however.
I hand-tuned a custom .config with only the present hardware configured, no special boot parameters.
The performance test was building the 6.16.0 kernel from scratch - a decent enough, repeatable task which takes long enough to give a representative result.
(But I’ve previously run much more in-depth benchmarks of Ampere, AWS Graviton, RK3588 & RPi systems - and the results track these, so I’m fairly confident they’re sound)
