According to the official Radxa website, the Dragon Q6A has a 5V input/output. Is it possible to power the board with 5V via the GPIO pins?
Hi Luiz,
The Type-C port and the 12V power input pins next to it can accept 5V power input. Please make sure to use a power supply that is at least capable of delivering 5V 3A for stable operations.
Thanks for the info. As there seems to be just a voltage regulator behind this: Can you tell me, how much “over voltage” above 12V will be acceptable? E.g. when using with a 3S LiOn battery, this provides 12.6V when fully charged (or a car 12V battery that can be charged up to 14.4V)?
It can handle 3.6V 4.5V to 16V power input.
Thanks, but with less than 5V, the USB outputs would not get enough voltage - or do you have also a step-up regulater for that onboard?
Do you know the voltage drop from the regulator? I assume, it should be powered at least with 5.3V in order to get 5V on the USB ports?
Thank you, it helped a lot.
The power flow is:
ADP12V (Type-C port and the 12V power input pins) → SY81012 DC/DC regulator → VPH_PWR / VPH_PERI (constant 4.2 V) → SY7120 Step Up Regulator → VCC_5V_PERI (constant 5 V for USB and other peripherals)
So, accounting for voltage drops and reliable operation of SY81012, it can handle 4.5V to 16V power input. Sorry for the incorrect infomation before.
