Hi! I’ve been able to use RKDev_Tool before but now it’s telling me Loading Config File Failed?
Am I missing something?
BR,
Robert.
BR,
Robert.
Sam USB port and cable?
I got this issue with usb-A, usb-C worked perfectly.
Thanks! But it didn’t work, I’ll try with my old laptop next.
/Robert
RkDevTools is on version 3.25 or so… and the load the file is just a saved config file which means that u can reproduce that aspect of rkdev to flash ur images spi etc. The excel look has options that u can add remove or change to make them look just as like in this image:
Where to download the latest version of rkdevtools? Good question. Idk either but other vendors have updated it while radxa still shows the 2.96
Does it matters ? Honestly… no the 2.96 does the job.
I won’t rush with update, in fact I’m keeping about four of them now because it’s just easier to use the one that was supported at time and for older board. As example - I recently needed to flash ROCK 4B+, v2.96 did not worked, but same thing with v2.86 did the job smoothly. Most recent version may be better, but I bet that they don’t test that with everything. Still we need specific cable and port to make this to work. Of course this may change with recent windows versions or updates, so far no problem to keep few
BTW: this is RkDevTool changelog up to v3.19 (which is quite old now and probably already updated):
v3.19 revision(2023/09/11)
1.get transfer max limit after switch storage
v3.18 revision(2023/07/03)
1.fix grow partition ending lba bug
v3.17 revision(2023/05/11)
1.add convert relative path into absolute path function
2. fix export config without set partsize bug
v3.16 revision(2023/05/04)
1.add close_check_idb into config.ini
v3.15 revision(2023/02/23)
1.support download jffs image
v3.14 revision(2023/02/02)
1.add force_data_band to control transfer package size per time
v3.13 revision(2022/11/10)
1.support to download update.img on the second storage
v3.12 revision(2022/10/28)
1.rkimageMaker binary update
2.add check entry size on loading multi-storage
v3.11 revision(2022/10/11)
1.add try catch on scan
2.fix some buffer init bug on library
v3.1 revision(2022/09/08)
1.fix chunk data size large 4G bug on download sparse
v3.0 revision(2022/08/19)
1.fix export config without saving partiton size
2.fix multi-storage compatible bug
v2.99 revision(2022/08/08)
1.support new format multi-storage firmware
2.add unpack multi-storage firmware
v2.98 revision(2022/08/04)
1.support multi-storage firmware with div
v2.97 revision(2022/06/13)
1.add lba parity
2.set idblock fixed 2 copy
v2.96 revision(2022/06/07)
1.support to upgrade env update.img
2.fix two parameter bug on multi-storage case
v2.95 revision(2022/05/19)
1.fix double download boot on upgrading update.img
v2.94 revision(2022/03/17)
1.free rkimage resource when loading fw done
2.reload rkimage fw before downloading
v2.93 revision(2021/12/31)
1.support to parse efi partition flag on gpt parameter
2.fix partsize update without downloading parameter
v2.92 revision(2021/11/30)
1.support 4 images for idblock
2.support one single idblock for nor flash
v2.91 revision(2021/11/10)
1.add check pagesize during download ubi image
2.add destrory gpt during download parameter
v2.9 revision(2021/09/22)
1.test storage operation pass
2.support custom vidpids
v2.89 revision(2021/09/07)
1.check partition size and offset if larger than flash
v2.88 revision(2021/08/26)
1.support to choose device when more devices connected
2.give prompt for error
v2.87 revision(2021/07/30)
1.support to download firmware into different storage
v2.86 revision(2021/05/26)
1.support to write image by address
v2.85 revision(2021/05/20)
1.handle erase emmc without eraselba
v2.84 revision(2021/04/30)
1.fix lastusedlba in gpt bug
v2.83 revision(2021/04/19)
1.reloading the modified firmware when upgrading
v2.82 revision(2021/03/23)
1.modify lastusedlba in gpt to assure that align with 64 sector
v2.81 revision(2021/01/28)
1.support to list storage and switch storage
v2.8 revision(2021/01/04):
1.fix chunk size beyond 4g in sparse download
v2.79 revision(2020/11/11):
1.support new loader format
v2.78 revision(2020/11/02):
1.support to create download list from parameter
v2.76 revision(2020/09/25):
1.complete to download new idblock
v2.75 revision(2020/09/15):
1.fix virtual list grid msg collision
v2.74 revision(2020/07/23):
1.take small slice to erase nor flash
v2.73 revision(2020/05/20):
1.support with exporting com log
v2.72 revision(2020/01/13):
1.fix erase flash is timeout on nor flash up
v2.71 revision(2019/08/21):
1.fix download image at last partition bug up
2.optimize the progress of downloading
According to logs several small issues were fixed and some new features about multi-images, jffs, second/multi storage and some partition formats. Nothing that You need until You know about those.
Of course maybe new images would require some of those. Certainly no usb/driver/communication updates so still we will have those weird errors on wrong cable/port.
if anybody interested, v3.15 is available i.e. on orange pi downloads: https://drive.google.com/drive/folders/14nfB_DpYZzsVVhC-B3nx7thLTewElAAz
v3.19 from friendlyelec (at least is by default in English):
https://drive.google.com/drive/folders/1Usla7kNUYVzbMFYN_Aey9NUqgUfXwvqR
Are u sure that the 2.96 didnt worked ? Were the spl file updated ? and the image extracted? ive done a lot of them flashings on cm5 and with older and newer versions never failed me so far to the point of saying that only worked with one version.
Thanks for link, recent changes here:
v3.28 revision(2024/03/13)
1.fix create gpt for 1sector lba bug
2.add spare idblock support to fill spare areav3.27 revision(2024/03/08)
1.fix create gpt for 4k
2.fix to read and parse gpt for 4k
3.fix to wait usbplug after download bootv3.26 revision(2024/02/25)
1.support to download gpt info 4k ufs device
2.set erase one size as 128k for nor flash
3.support to set crc off for downloading 471 and 472v3.25 revision(2023/12/22)
1.support to usb2 reconnection when failure of swiching usb3v3.24 revision(2023/12/12)
1.add usb transfer 4m handshake with devicev3.23 revision(2023/10/18)
1.fix load config bug in non-chinese-english osv3.22 revision(2023/10/08)
1.fix env firmware check condition bugv3.21 revision(2023/09/22)
1.support mousewheel to scroll download itemv3.20 revision(2023/09/15)
1.support usb3 download
This may be specific to image, I can see in changelog that they corrected several small issues,
Newer version failed to finish whole process, older was ok with same setup and same thing to do. I’ll recheck that later as well as recent versions.
But the question remains… where the f…is the oficial source of the tool? I cant find anything on google about where to download the latest and greatest version of the tool. And so… we have to be ‘digging’ from vendor to vendor… makes no sense to me
I don’t know either,
probably it’s distributed with all docs straight from rockchip for partners and it’s up to them to publish whenever they need. For linux version there is also not so much changes in official rkdeveloptool but at least its open source so there are updated forks
