5B+ reboot hang, power cycle needed
Hi, using 12V6A fixed, so powersupply shoudl not be issue. Booting from NVMe (through SPI bootloader) is working. But in no setup reboot works.
Even using SD card only, and official radxa rock-5b-plus_bookworm_kde_b2.output.img.xz, after rebooting flash remains green until I cycle power.
Is it wrong board? Tried various armbian builds, differen powersupplies as well.
Like always - UART console shows what is the problem, when it happens, were any errors reported etc.
Attaching this here makes debugging way easier :slight_smile:
You mean buying USB-TTL cable? Ok at least its way forward, thx.
@ken Please pay attention to this issue
cannot boot again after reboot? just re-plug the power ?
yep exactly, but that not really viable if you need to use 5b+ as a remote server
Pls take a clear photo around the wifi
what are we looking for?
Do you have a USB-TTL cable to get the fail log?
Make sure your `USB-TTL or if you are going to get one does 1.5Mbps.
@ken Took me a while to get the USB-TTL, but can you please check the fail log for me pls?
Behaviour is that after sudo reboot it eventualy hangs with error ERR until I power cycle.
minicomcap.zip (7.7 KB)
Have you made any modifications to the image? For example, uboot.
Use the following image to test and if it can be reproduced.
https://github.com/radxa-build/rock-5b-plus/releases/download/b2/rock-5b-plus_debian_bullseye_kde_b2.img.xz
Hi, no i used official bookworm image without any modifications. But i reproduced now with the bullseye as well. (Also its is case with armbian images).
attaching UART capture of bullseye.minicom.zip (6.6 KB)
Please use rsetup to update the bootloader. If the situation remains the same, please contact after-sales service for handling.
