5B cannot boot DietPi off nvme (sdcard works fine)
I’m having some trouble getting my board to boot off a NVMe drive (WD 1TB). I was able to flash the same image to an sd card, dd it to the nvme drive, but when I go to boot without the SD card I get no kernel.
Note my debugging capabilities are a bit limited. My capture of the U-boot log is via a logic analyzer since my TTL cable doesn’t support the correct baud. So currently I cannot interact with the terminal (I am looking to see if I can fix that with a teensy).
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
Manufacturer ID:0xff
CH0 RX Vref:28.7%, TX Vref:21.8%,0.0%
CH1 RX Vref:28.7%, TX Vref:20.8%,0.0%
CH2 RX Vref:27.7%, TX Vref:20.8%,0.0%
CH3 RX Vref:27.7%, TX Vref:20.8%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-g3caf61a44c2-220414 #stephen (Sep 29 2022 - 18:14:19)
Trying to boot from MMC2
MMC: no card present
mmc_init: -123, time 0
spl: mmc init failed with error: -123
Trying to boot from MMC1
mmc_init: -95, time 14
spl: mmc init failed with error: -95
Trying to boot from MTD2
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK
## Checking uboot 0x00200000 ... sha256(6a08776395...) + OK
## Checking fdt 0x0030a010 ... sha256(d32827d3ac...) + OK
## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK
## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK
## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 499.428 ms
\x01INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE:  BL31: Built : 11:23:47, Aug 15 2022
INFO:    spec: 0x1
INFO:    ext 32k is not valid
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    system boots from cpu-hwid-0
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-g3caf61a44c2-220414 #stephen (Sep 29 2022 - 18:14:19 +0800)
Model: Radxa ROCK 5B
PreSerial: 2, raw, 0xfeb50000
DRAM:  7.7 GiB
Sysmem: init
Relocation Offset: edb6d000
Relocation fdt: eb9f9cd8 - eb9fecc8
CR: M/C/I
Using default environment
Hotkey: ctrl+`
SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Bootdev(atags): mtd 2
PartType: EFI
DM: v2
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
  b0pll 24000 KHz
  b1pll 24000 KHz
  lpll 24000 KHz
  v0pll 24000 KHz
  aupll 24000 KHz
  cpll 1500000 KHz
  gpll 1188000 KHz
  npll 24000 KHz
  ppll 1100000 KHz
  aclk_center_root 702000 KHz
  pclk_center_root 100000 KHz
  hclk_center_root 396000 KHz
  aclk_center_low_root 500000 KHz
  aclk_top_root 750000 KHz
  pclk_top_root 100000 KHz
  aclk_low_top_root 396000 KHz
No misc partition
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
invalid flags type!
Device 0: Vendor: 0x15b7 Rev: 731100WD Prod: 23085A802407
            Type: Hard Disk
            Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
... is now current device
Scanning nvme 0:1...
2666 bytes read in 2 ms (1.3 MiB/s)
## Executing script at 00500000
SCRIPT FAILED: continuing...
no mmc device at slot 1
no mmc device at slot 0
Device 2: Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor
            Type: Hard Disk
            Capacity: 16.0 MB = 0.0 GB (32768 x 512)
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
Device 1:
Device 0: unknown device
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
Could not get mtd 0
## Booting FIT Image FIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Unknown command 'bootrkp' - try 'help'
One other side note I have noticed is that if I check the spi flash’s md5sum after a power cycle it changes, not sure if that is WAI or not.
I can see in the log it finds the drive but fails to boot off the script, I am not a u-boot expert so I have no clue how to check this but will happily take some pointers.
looks like it is a dietpi issue, flashed the radxa debian image to the nvme and I can’t login via ssh so it means the keys changed and I booted to something else.
