Hello all, in case some of you wanted to attach their o6 to a wall, I designed a handy wall mount here : https://www.thingiverse.com/thing:7004220
Actually works quite well. I provided all the openscad sources etc so feel free to explore, enhance, criticize, etc
I was thinking about making walls for it that can be keep in place by pressure with the top acrillic.
This is a slider mount. Which let you take it off in no time.
How about that ?
The idea : slide the bottom of the orion acrilic case, push it in the case, slide the top slider down. Should hold everything in place.
Available on thingiverse too as a testing model : HERE
Just FYI : OpenSCAD won’t run on the o6 radxa debian image atm. issues with QT libraries probably due to the driver being “ad hoc” and note totally compatible with some GUI libraries.
Eventually printed the frame version.
Looks way classier, simple design, and very effective and sturdy.
It requires a bit more of filament than the “over engineered” version, but it definitely is worth it in terms of look.
