25W PoE+ HAT GPIO interface
I have a Rock 4D SBC and am trying to power it over Ethernet. Hence the subject.
  1. Are any of the GPIO pins available while this HAT is installed? What components are needed to extend/split the available pins if it is possible?
My confusion is coming in part from seeing most images of the 25W PoE HAT with open holes in the area of the GPIO header. However, there is at least one image showing solder across each of the GPIO header positions.
  1. Is the 25W PoE+ HAT compatible with the Rock 4D? The HAT documentation page lists
  • Rock 3A/B/C
  • Rock 4C+
  • Rock 5A/B
  • Cubie A7A
…but on the bottom of the product for the same PoE HAT it shows Rock 4D as compatible. So, I’m guessing I can trust that but want to check against real experience while I have your attention.
Apologies if these are dumb question but I hope someone will answer anyway. :slight_smile:
