Can someone make available the prior spi-file for rock 5 b?
Thanks in advance
Uli
you can find them here https://dl.radxa.com/users/dev/rock-5b/, but we suggest you update the lastest spi version which improves the stability
Hello Peter,
with the last version , I guess from 2023 I could start from sd-card the [edk2-rk3588] uefi bootloader.
Then I coud start from usb my opensuse iso-live image. Right now the uefi bootloader does not start anymore . The spi bootloader does not detect the uefi-loader on the sd-card.
any advise or help?
thanks in advance
Uli
Hello Peter,
thank you for your help. I never had aproblem with the spi-file.
If you make this changes, please can you communicate the differences and advantages in the future.
Thanks
Uli
this spi file contains rockchip’s lastest patches and can improve the stability of system, someone reported the system will freeze when system running on nvme and the newest spi version fixed it.
Hello, could you please point to the place where the latest bootloader image is published?
Thank you!
