Does anyone have any solution for getting 12V USB-C into a Radxa X2L from a PoE to 12V adapter? I have found such adapters but they terminate in 5.5x2.1 barrel connectors and I can’t find anything that can take a 12V barrel connector and deliver it as a 12V USB-C connector. I really wish there were an option to power the X2L using 12V directly on a barrel connector and not through USV-C connectors. There is just not much hardware out there other than straight mains-to-USB-C single power sources that can deliver 12V on a USB-C connector!
Otherwise, is there any solution from Radxa for PoE hardware to power the X2L???
I have tried three different models so far with no success. The ones on the market are designed to work in the opposite direction, to supply 12V DC to a barrel connector from a usb-c power supply.
Can Radxa either find and offer a connector that will work in the right direction, or provide a PoE option to power the X2L directly? My use case is to run a small cluster of X2Ls and PoE would simplify things immensely.
I have similar issue, i want to power the board with 12v dc but without success. I used dc to to usb c adapter and also tried to just cut usb c (power only) cable and supplying 12v to cable. In both cases board trying to start up for 1 sec and shutdowns.
I think board is trying to negotiate with cable.
Is there any way to just power up the board with 12v without PD?
I use 12v 4a power supply.
The PD issue is known and we have fixed it for the next batch shipping X2L, You can also replace the resistors and capacitors on the board yourself if you have the ability and equipment to do so.
I ended up building an adapter by converting an automotive 12V to USB-C charger by wiring a barrel connector to it. This works well and I was able to buy a box of 10 of these chargers for $50 so not too expensive either. I’m glad to know the next batch will address this issue however!
Well, I have to card and this morning I was facing power interruption.
Then I bought a low cost UPS. The first card is fine with it, barrel to usb-c connector. The second one I use for my xpenlogy is not. I guess it is because it’s the first one I bought with PD error.
If I bought today another X2L 4Go RAM, does the card will be the new version with the PD issue corrected? Is there any batch info written on the card to be sure?
If your X2L version is v1.32 or later, then you can power with 12V USB C DC. Check with the distributor about the hardware revision before put the order.
To avoid any misunderstanding and to avoid embarrassing myself:
By replacing R243 and C270, I can feed the 12VDC directly via USB-C and am no longer dependent on USB-PD.
Is that correct? Thanks in advance.
Hello, I would like to ask, does anyone know which revision is currently available in the official store on aliexpress? Because they don’t understand the question there, unfortunately.
