Hi. There is a known issue with the RTC that causes the system date to be set hundreds of years in the future. This behavior disrupts system services and is the root cause of the high CPU usage and the interface issues you are experiencing.
As a temporary workaround, please manually set the correct date in PowerShell using the command below:
Set-Date -Date "12/14/2025 4:30 PM"
