I have just purchased Rock Pi and I encountered problem with powerbank.
Power consumption at idle is too low for the powerbank to stay on. It just switches itself off while it “thinks” it has nothing attached. I tried two different powerbanks and result was the same. When connected to USB on running PC it is running all day fine.
It is running latest minimal image of Debian from NAND. No card is even present at this time. No WiFi or BT connection.
Is there any solution other than just put there some artificial load?
I will eventually connect some peripherals, but I like to be sure it does not switch off on self, while I plan to use it for some unattended data collection from RS485 and CAN.
Best regards
Vit Soucek
