I decompiled the dtb file ‘rk3308-rock-pi-s.dtb’ into dts using following command:
dtc -I dtb -O dts -o rk3308-rock-pi-s.dts rk3308-rock-pi-s.dtb
In the resulting .dts file there were three USB nodes:
usb@ff400000 {
compatible = “rockchip,rk3066-usb\0snps,dwc2”;
reg = < 0x00 0xff400000 0x00 0x40000 >;
interrupts = < 0x00 0x42 0x04 >;
clocks = < 0x02 0x9e >;
clock-names = “otg”;
dr_mode = “otg”;
g-np-tx-fifo-size = < 0x10 >;
g-rx-fifo-size = < 0x118 >;
g-tx-fifo-size = < 0x100 0x80 0x80 0x40 0x20 0x10 >;
g-use-dma;
phys = < 0x67 >;
phy-names = “usb2-phy”;
status = “okay”;
phandle = < 0xc8 >;
usb@ff440000 {
compatible = "generic-ehci";
reg = < 0x00 0xff440000 0x00 0x10000 >;
interrupts = < 0x00 0x47 0x04 >;
clocks = < 0x02 0x9f 0x02 0xa0 0x1b >;
clock-names = "usbhost\0arbiter\0utmi";
phys = < 0x68 >;
phy-names = "usb";
status = "okay";
phandle = < 0xc9 >;
usb@ff450000 {
compatible = "generic-ohci";
reg = < 0x00 0xff450000 0x00 0x10000 >;
interrupts = < 0x00 0x48 0x04 >;
phys = < 0x68 >;
phy-names = "usb";
status = "okay";
phandle = < 0xca >;
There was no dwc node in that file, not even as subnode in one of the usb nodes.
From RK3308 reference manual, I found that usb@ff400000 is the node for USB OTG. So I added the maximum-speed parameter in that node like this:
usb@ff400000 {
dr_mode = “otg”;
g-use-dma;
phys = < 0x67 >;
status = “okay”;
phandle = < 0xc8 >;
maximum-speed = “full-speed”;
I recompiled the .dts using following command:
dtc -I dts -O dtb -o rk3308-rock-pi-s_2.dtb rk3308-rock-pi-s.dts
Edited the /boot/uEnv.txt file to load the new dtb file:
fdtfile=rockchip/rk3308-rock-pi-s_2.dtb
and rebooted. But still OTG was not working in forced Full-speed mode. I loaded g_ether driver using modprobe and connected usb to a pc but it was trying to connect in high-speed.
dmesg output:
root@rockpis:~# modprobe g_ether
[ 180.861975] using random self ethernet address
[ 180.862622] using random host ethernet address
[ 180.864102] usb0: HOST MAC 0e:ba:71:f1:99:04
[ 180.872148] usb0: MAC 86:8a:c6:06:f6:4f
[ 180.872621] using random self ethernet address
[ 180.873084] using random host ethernet address
[ 180.873654] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 180.874360] g_ether gadget: g_ether ready
[ 180.877826] dwc2 ff400000.usb: bound driver g_ether
root@rockpis:~# [ 235.819745] dwc2 ff400000.usb: new device is high-speed
[ 236.568559] dwc2 ff400000.usb: new device is high-speed
[ 237.348594] dwc2 ff400000.usb: new device is high-speed
[ 238.128627] dwc2 ff400000.usb: new device is high-speed
