Hi Jack,
uname -r output is:
4.4.154-59-rockchip-g5e70f14
Barry
Hi Jack,
uname -r output is:
Barry
Please update the kernel package according to the wiki page:
I think we have fixed this issue. The latest kernel is linux-image-4.4.154-92 you just install the
sudo apt-get install linux-4.4-latest
Hi Jack,
Thanks for reply. I have updated the kernel to latest as your suggestion. But the problem still exist. Now dmesg output is slightly different.
[Mon Oct 21 17:07:57 2019] bcmsdh_sdmmc: Failed to Read byte F1:@0x1001f=ff, Err: -5
[Mon Oct 21 17:07:57 2019] dwmmc_rockchip fe310000.dwmmc: All phases bad!
[Mon Oct 21 17:07:57 2019] mmc2: tuning execution failed
And I found wlan0 actually is connected and got ip address even eth0 is disconnected. But ssh to wlan0 got no response if eth0 is unplug.
After plugin eth0 and eth0 then wlan0 would response to ssh too.
Regards,
Barry
I think this issue is fixed in the latest kernel. Please update to the linux-4.4-latest_4.4.154-98-rockchip and later.
hi installing the lastest kernel, specifically the linux-4.4-latest_4.4.154-95-rockchip no appear the wifi and is poor, solutions please or i consider use other option for this, with the default kernel works and connect but new no working nothing
The kernel version should not affect the wifi signal. Could you check if there is other reasons? such as did you put the board in a metal case?
You are a legend, That one worked!
(Linux Mint with Plasma Theme)my .conf had no
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:wwan,except:type:ethernet
