Urgent: Radxa Rock 5 ITX, USB stops working after grub
UEFI EDK 2 , USB functional, keyboard and mouse functional
Grub, USB keyboard functional
firmware bye-bye, linux kernel loads, USB goes down!
3a. All USB ports and connectors go down!
3b. USB keyboard/mouse not functional!
3c. USB flash drive no longer detected!
3d. USB ssd/hdd, which was detected during boot from file at UEFI, no longer detected!
Cannot install an OS. Cannot boot an already installed generic OS from external ssd, because it is no longer operational after grub. All the USB ports stop working after we select the boot target from grub and linux kernel starts loading and UEFI goes away! Even keyboard and mouse stop!
Both Radxa Rock 5 ITX and Rock 5B+ have the same issue!
Had big plans to switch to ARM64 ecosystem. All of them halted!
Please help!
Rock 5 ITX (not plus, the plain one only) and Rock 5B+.
I have the itx+. I finally got around installing the plain Armbian vendor image without roobi but no luck getting the UEFI image booting. Burned the img to SD. No Go. Flashed to mmcblk0, same. Just doesn’t come on.
Also how do I get a current kernel working? 6.1 vendor works, but not the 6.12.
That said, I got UEFI working on both of my Rock 5b with Fedora 43 Rawhide (and 42 with DT). Can’t be that much off
In order to create working images (which can be used by any untrained user, just record the image and it will work immediately without additional complex manual manipulations), need to conduct tests on real equipment. I don’t have such equipment, sorry, I can’t help you in any way.
