The architecture name changes when the machine code representation used by the shader cores change:
Utgard had separate vertex and fragment shading cores, Midgard was VLIW with three vector units and two scalar units, Bifrost was VLIW with two scalar units, and Valhall uses a simple stream of eight-byte instructions.
So even if the entire rest of the GPU changes, only the shader cores matter for architecture naming.
But even looking at GPU structures, the Valhall GPUs are all very similar to each other, apart from CSF. Bifrost is much closer to Midgard than it is to Valhall in that regard, but the entire fragment processing pipeline from rasterization to blending is almost unchanged for the different Valhall generations.
