Rock Pi 4B Debian KDE not boot from NVMe
I have fixed the RESET bug. Please try this one.
u-boot.zip (980.3 KB)
If you can get it working with RKDevTool, then go ahead with it.
In short, I did it! I started Debian with NVMe SSD (without SD card)!
And now in more detail:
I downloaded an image of the corrected u-boot and tried to program the SPI memory:
  1. $ sudo dpkg -i u-boot-latest_2024.01-1_amd64.deb
  2. $ cd /usr/lib/u-boot/rock-pi-4b/
  3. $ sudo bash ./setup.sh update_spinor /dev/mtd0
The recording failed:
I took the spi.img image from the /tmp folder. using the rkdeveloptool software, I programmed the spi memory. This process was successful. I tried to boot from my NVMe SSD KingSpec NX series. Unsuccessfully.
UART Log:
DDR Version 1.25 20210517
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000338d4e0 + 0x0:0x3b,0x8c,0xdc,0xfc,0xbe,0x9f,0x9d,0x51,0xeb,0x30,0x34,0xce,0x24,0x51,0x1f,0x98,
tag:LOADER error,addr:0x4000
Load uboot, ReadLba = 2400
hdr 000000000338d4e0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
tag:LOADER error,addr:0x4400
Load uboot, ReadLba = 2800
tag:LOADER error,addr:0x4800
Load uboot, ReadLba = 2c00
tag:LOADER error,addr:0x4c00
Load uboot, ReadLba = 3000
Load OK, addr=0x200000, size=0xfb918
RunBL31 0x40000 @ 2197200 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot latest-2024.01-1-g31b85240 (Jan 31 2024 - 09:10:14 +0000)
SoC: Rockchip rk3399
Reset cause: POR
Model: Radxa ROCK 4B
DRAM: 4 GiB (effective 3.9 GiB)
PMIC: RK808
fan53555_probe: FAN53555 option 8 rev 1 detected
fan53555_rk860_calibration>>>>>>hardware 0x40 i2c-dev is not rk860-0, maybe syr827/syr837, reg[0x0e] = 0x1
fan53555_rk860_calibration>>>>>>hardware 0x41 i2c-dev is not rk860-1, maybe syr828/syr838, reg[0x0e] = 0x97
fan53555_rk860_calibration>>>>>rk860_type = 0
fan53555_rk860_calibration>>>>>>do nothing
fan53555_rk860_calibration>>>>>>hardware 0x40 i2c-dev is not rk860-0, maybe syr827/syr837, reg[0x0e] = 0x8f
fan53555_rk860_calibration>>>>>>hardware 0x41 i2c-dev is not rk860-1, maybe syr828/syr838, reg[0x0e] = 0x1
Core: 292 devices, 30 uclasses, devicetree: separate
MMC: mmc@fe320000: 1, mmc@fe330000: 0
Loading Environment from MMC… Card did not respond to voltage select! : -110
*** Warning - No block device, using default environment
In: serial,usbkbd
Out: serial,vidconsole
Err: serial,vidconsole
Unable to get mmc desc
Net: eth0: ethernet@fe300000
starting USB…
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3c0000: USB EHCI 1.00
Bus usb@fe800000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fe900000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@fe380000 for devices… 4 USB Device(s) found
scanning bus usb@fe3c0000 for devices… 1 USB Device(s) found
scanning bus usb@fe800000 for devices… 1 USB Device(s) found
scanning bus usb@fe900000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Hit Ctrl+C key in 0 seconds to stop autoboot…
** Booting bootflow ‘nvme#0.blk#1.bootdev.part_2’ with extlinux
U-Boot menu
1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
2: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip (rescue target)
Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
Retrieving file: /boot/vmlinuz-5.10.110-8-rockchip
Retrieving file: /boot/initrd.img-5.10.110-8-rockchip
append: root=UUID=42144245-5b54-455d-a53b-c3b9910baee3 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty0 console=ttyFIQ0,1500000n8 console=ttyAML0,115200n8 console=ttyS2,1500000n8 console=ttyS0,1500000n8 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 plymouth.ignore-serial-consoles cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Retrieving file: /usr/lib/linux-image-5.10.110-8-rockchip/rockchip/rk3399-rock-pi-4b.dtb
Moving Image from 0x2080000 to 0x2200000, end=3d80000
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Working FDT set to 1f00000
Loading Ramdisk to f4137000, end f4ed53d7 … OK
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
Loading Device Tree to 00000000f411b000, end 00000000f413654f … OK
Working FDT set to f411b000
Starting kernel …
[ 13.672599] ramoops ramoops: failed to locate DT /reserved-memory resource
[ 13.732910] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 13.732942] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 13.732958] fiq_debugger_probe: could not install nmi irq handler
[ 15.418975] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: IRQ index 0 not found
[ 15.421994] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: IRQ index 0 not found
[ 15.431493] rkvdec_init:1230: failed on clk_get clk_hevc_cabac
[ 15.431582] mpp_rkvdec ff660000.rkvdec: shared_video_hevc_cabac is not found!
[ 15.431598] rkvdec_init:1261: No hevc cabac reset resource define
[ 15.454250] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 15.454550] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 16.213048] no ATF memory for init
[ 16.225986] no ATF memory for init
[ 16.230519] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 16.525675] vcc_cam: failed to get the current voltage: -EPROBE_DEFER
[ 16.526127] vcc_mipi: failed to get the current voltage: -EPROBE_DEFER
[ 16.550538] vcc_sdio: unsupportable voltage range: 3300000-3000000uV
[ 16.552566] rockchip-dmc dmc: Failed to get ddr_leakage
[ 16.553390] rockchip-dmc dmc: could not find power_model node
[ 16.558528] rksfc_base v1.1 2016-01-08
[ 16.665745] Internal error: synchronous external abort: 96000210 [#1] SMP
[ 16.666576] Modules linked in:
[ 16.666967] CPU: 3 PID: 144 Comm: kworker/u12:2 Not tainted 5.10.110-8-rockchip #f9d1b1529
[ 16.667929] Hardware name: Radxa ROCK Pi 4B (DT)
[ 16.668489] Workqueue: events_unbound deferred_probe_work_func
[ 16.669188] pstate: 60000085 (nZCv daIf -PAN -UAO -TCO BTYPE=–)
[ 16.669904] pc : rockchip_pcie_rd_conf+0x160/0x1b4
[ 16.670478] lr : rockchip_pcie_rd_conf+0x150/0x1b4
[ 16.671048] sp : ffff800012b337c0
[ 16.671452] x29: ffff800012b337c0 x28: 0000000000000001
[ 16.672089] x27: 0000000000000000 x26: 0000000000000000
[ 16.672728] x25: ffff8000110c9a6a x24: 0000000000000000
[ 16.673366] x23: ffff000005e58c00 x22: 0000000000000000
[ 16.674004] x21: 0000000000000004 x20: ffff800012b33844
[ 16.674642] x19: ffff800014100000 x18: 0000000000000000
[ 16.676270] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 16.679623] x17: 0000000000000000 x16: 0000000000000000
[ 16.679633] x15: 000000000000000a x14: 00000000000005fa
[ 16.679644] x13: ffffffffffffffff x12: ffffffffffffffff
[ 16.679654] x11: 0000000000000000 x10: ffff000005dd9a1c
[ 16.691516] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 270
[ 16.695495] x9 : ffff8000105bab78 x8 : 01001d8700000000
[ 16.695506] x7 : 000000000000ea60 x6 : ffff800012b338f4
[ 16.695516] x5 : 0000000000000000 x4 : 0000000000000000
[ 16.695526] x3 : 0000000000c00008 x2 : 000000000080000a
[ 16.695536] x1 : ffff800017c00008 x0 : ffff800014000000
[ 16.695547] Call trace:
[ 16.695560] rockchip_pcie_rd_conf+0x160/0x1b4
[ 16.703274] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 16.705528] pci_bus_read_config_dword+0x84/0xdc
[ 16.705538] pci_bus_generic_read_dev_vendor_id+0x48/0x174
[ 16.705547] pci_bus_read_dev_vendor_id+0x74/0x7c
[ 16.705561] pci_scan_single_device+0x78/0xf0
[ 16.761472] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 16.765586] pci_scan_slot+0x80/0xf4
[ 16.765596] pci_scan_child_bus_extend+0x74/0x300
[ 16.765609] pci_scan_bridge_extend+0x488/0x54c
[ 16.766948] rockchip-pm-domain ff310000.power-management:power-controller: Looking up sdioaudio-supply from device tree
[ 16.767018] rockchip-pm-domain ff310000.power-management:power-controller: Looking up sdioaudio-supply property in node /power-management@ff310000/power-controller failed
[ 16.770507] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 16.774929] pci_scan_child_bus_extend+0x2c4/0x300
[ 16.774939] pci_scan_child_bus+0x20/0x2c
[ 16.774951] pci_scan_root_bus_bridge+0x9c/0xd4
[ 16.779484] usb 1-1: Product: USB2.0 HUB
[ 16.783891] pci_host_probe+0x28/0xb0
[ 16.783902] rockchip_pcie_really_probe+0x150/0x164
[ 16.783911] rockchip_pcie_probe+0x304/0x360
[ 16.783925] platform_drv_probe+0x60/0xb0
[ 16.790317] hub 1-1:1.0: USB hub found
[ 16.798731] really_probe+0x2dc/0x46c
[ 16.798741] driver_probe_device+0x138/0x148
[ 16.798754] __device_attach_driver+0xd8/0x114
[ 16.803902] hub 1-1:1.0: 4 ports detected
[ 16.808214] bus_for_each_drv+0xa4/0xcc
[ 16.808223] __device_attach+0xdc/0x170
[ 16.808237] device_initial_probe+0x20/0x2c
[ 16.875094] bus_probe_device+0x3c/0xa0
[ 16.879300] deferred_probe_work_func+0xe0/0xf4
[ 16.883585] process_one_work+0x1e0/0x298
[ 16.887850] process_scheduled_works+0x4c/0x50
[ 16.892204] worker_thread+0x1f8/0x27c
[ 16.896521] kthread+0xf8/0x108
[ 16.900731] ret_from_fork+0x10/0x30
[ 16.904973]
[ 16.904973] PC: 0xffff8000105bab88:
[ 16.912919] a988 11700023 11002063 32090042 8b234083 b9000062 d50332bf f9400400 11700021
[ 16.917652] a9a8 11003021 8b214001 b900003f 52800000 d50323bf d65f03c0 128002a0 17fffffd
[ 16.922435] a9c8 d503245f aa1e03e9 d503201f d503233f a9be7bfd d2800003 910003fd a90153f3
[ 16.927297] a9e8 aa0003f4 2a0103f3 2a1303e0 f0ffd962 d0009941 91189042 9105e021 97ecbe88
[ 16.932130] aa08 f9401281 2a1303e0 97ecbbad 52800000 a94153f3 a8c27bfd d50323bf d65f03c0
[ 16.936943] aa28 d503245f aa1e03e9 d503201f d503233f a9bc7bfd 910003fd a90153f3 aa0403f4
[ 16.940206] usb 4-1: new full-speed USB device number 2 using ohci-platform
[ 16.941851] aa48 a9025bf5 2a0303f5 53037c23 f9001bf7 f9400804 f9406817 b4000064 f9400885
[ 16.951636] aa68 b5000665 72001076 54000160 12800000 528010d6 b9000280 2a1603e0 a94153f3
[ 16.956680] aa88 a9425bf5 f9401bf7 a8c47bfd d50323bf d65f03c0 b50004c4 f94006e0 93407c42
[ 16.961589] aaa8 91600042 93407ea1 d1000421 8b020000 ea01001f 54000080 528010f6 b900029f
[ 16.966488] aac8 17ffffee 710012bf 54000101 b9400002 d50331bf 2a0203e0 ca000000 b5000000
[ 16.971355] aae8 b9000282 17ffffe5 71000abf 54000121 97ffff8a 12003c01 d50331bf 92403c00
[ 16.976329] ab08 ca000000 b5000000 b9000281 17ffffdb 710006bf 54fffd21 97ffff7c 12001c01
[ 16.981387] ab28 d50331bf 92401c00 17fffff6 b94142f6 350004f6 39438013 53111063 53140821
[ 16.986516] ab48 12002c42 2a020022 510006a0 2a135073 2a020273 6a13001f 54fffb01 f9400880
[ 16.991720] ab68 b50001e0 52800141 aa1703e0 94000969 710012bf 54000181 f94002e0 8b130013
[ 16.997000] ab88* b9400273 d50331bf 2a1303e0 ca000000 b5000000 b9000293 17ffffb8 52800161
[ 17.002356] aba8 17fffff2 71000abf 54000081 f94002e0 8b130000 17ffffcf 710006bf 54fff7e1
[ 17.007777] abc8 f94002e0 8b130000 17ffffd4 52800016 17ffffaa aa1e03e9 d503201f d503233f
[ 17.013276] abe8 8b214000 b9400000 d50331bf 2a0003e1 ca010021 b5000001 d50323bf d65f03c0
[ 17.018844] ac08 d503245f aa1e03e9 d503201f d503233f a9bb7bfd 910003fd a90153f3 9100c013
[ 17.024508] ac28 a9025bf5 a90363f7 a9046bf9 f9402416 f9400417 f9402ac0 f94066f9 b5000160
[ 17.030234] ac48 f94022c1 b4000081 aa1303e0 d63f0020 14000006 f9401ec1 aa1303e0 d63f0020
[ 17.036015] ac68 f9401ac1 b5ffff21 f94006e0 52800a01 f0005898 91031318 d280003a 97ffffd6
[ 17.041866] ac88 d3452014 35000194 f9402ac1 b4000321 aa1303e0 d63f0020 a94153f3 a9425bf5
[ 17.047799] aca8 a94363f7 a9446bf9 a8c57bfd d50323bf d65f03c0 5ac00295 5ac012b5 9ad52340
[ 17.053819] acc8 0a200294 f9406ae0 93407ea1 97ecc86c 34000060 97eca4d3 17ffffeb 2a1503e2
[ 17.059910] ace8 aa1803e1 aa1903e0 941da8e0 17ffffe6 f94026c1 17ffffe7 d503245f aa1e03e9
[ 17.066066] ad08 d503201f d503233f a9bd7bfd 52800901 910003fd a90153f3 91004014 f90013f5
[ 17.072300] ad28 f9403e93 f9400660 97ffffab 120c0415 f9400660 52800781 97ffffa7 714c02bf
[ 17.078618] ad48 54000081 12001401 7100403f 54000060 52800020 b9014260 f8548260 97ff728d
[ 17.085006] ad68 f8548260 97ff732a f9406a60 97eccb3b f9400660 52801a01 72a01401 97ffff96
[ 17.091487]
[ 17.091487] LR: 0xffff8000105bab78:
[ 17.103252] a978 8b234083 b900007f d50332bf f9400404 11700023 11002063 32090042 8b234083
[ 17.109971] a998 b9000062 d50332bf f9400400 11700021 11003021 8b214001 b900003f 52800000
[ 17.116641] a9b8 d50323bf d65f03c0 128002a0 17fffffd d503245f aa1e03e9 d503201f d503233f
[ 17.123324] a9d8 a9be7bfd d2800003 910003fd a90153f3 aa0003f4 2a0103f3 2a1303e0 f0ffd962
[ 17.130006] a9f8 d0009941 91189042 9105e021 97ecbe88 f9401281 2a1303e0 97ecbbad 52800000
[ 17.136689] aa18 a94153f3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f
[ 17.143367] aa38 a9bc7bfd 910003fd a90153f3 aa0403f4 a9025bf5 2a0303f5 53037c23 f9001bf7
[ 17.150058] aa58 f9400804 f9406817 b4000064 f9400885 b5000665 72001076 54000160 12800000
[ 17.156711] aa78 528010d6 b9000280 2a1603e0 a94153f3 a9425bf5 f9401bf7 a8c47bfd d50323bf
[ 17.163341] aa98 d65f03c0 b50004c4 f94006e0 93407c42 91600042 93407ea1 d1000421 8b020000
[ 17.169965] aab8 ea01001f 54000080 528010f6 b900029f 17ffffee 710012bf 54000101 b9400002
[ 17.170537] usb 4-1: New USB device found, idVendor=1a86, idProduct=e2e3, bcdDevice= 0.00
[ 17.176585] aad8 d50331bf 2a0203e0 ca000000 b5000000 b9000282 17ffffe5 71000abf 54000121
[ 17.176616] aaf8 97ffff8a
[ 17.183310] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 17.189924] 12003c01 d50331bf 92403c00 ca000000 b5000000
[ 17.193614] usb 1-1.3: new low-speed USB device number 3 using ehci-platform
[ 17.196075] usb 4-1: Product: USB2IIC_CTP_CONTROL
[ 17.202578] b9000281 17ffffdb
[ 17.202587] ab18 710006bf 54fffd21 97ffff7c 12001c01 d50331bf 92401c00 17fffff6 b94142f6
[ 17.683399] X0: 0xffff800014000000:
[ 17.692986] fe00 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.696953] usb 1-1.4: new low-speed USB device number 4 using ehci-platform
[ 17.698523] fe20 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.707004] fe40 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.712617] fe60 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.718130] fe80 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.723525] fea0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.728678] fec0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.733567] fee0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.738288] ff00 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.742916] ff20 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.747450] ff40 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.751862] ff60 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.756206] ff80 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.760467] ffa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.764687] ffc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.768789] ffe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 17.772795] 0000* 52161dbe 00100000 01080201 00000000 00000004 00000000 00000000 00000000
[ 17.776870] 0020 00000000 00000000 00000000 52161dbe 00000000 00000040 00000000 000001ff
[ 17.780932] 0040 00035001 00000008 00000000 00000000 01807005 00000000 00000000 00000000
[ 17.784978] 0060 00000000 00000000 00000000 00000000 0002b010 10008fc2 00102010 00433843
[ 17.788957] 0080 10420000 00000000 00000000 00000000 00000000 0000081f 00000000 0000000e
[ 17.792882] 00a0 00000003 00000000 00000000 00000000 0008d011 00002000 00003000 00000000
[ 17.796765] 00c0 00000000 00000000 00000000 00000000 00000003 00000000 00000000 00000000
[ 17.800557] 00e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.804342] 0100 14820001 00000000 00400000 00462030 00000000 0000e000 000000a0 00000000
[ 17.808077] 0120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.811759] 0140 00000000 00000000 16810019 00000000 00000000 74007400 74007400 00000000
[ 17.815362] 0160 00000000 00000000 17010018 00000000 1801001e 00280a1f 00000000 00000028
[ 17.818918] 0180 1b81000b 03810001 00000000 00000010 00000000 00000010 00000000 00000000
[ 17.822463] 01a0 00d000d0 00d000d0 00000001 00000000 00000000 00000000 00010025 80000001
[ 17.825988] 01c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.829454] 01e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.832849]
[ 17.832849] X1: 0xffff800017c00008:
[ 17.838170] fe08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.841584] fe28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.844831] fe48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.847920] fe68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.850834] fe88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.853756] fea8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.856675] fec8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.859583] fee8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.862498] ff08 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.865407] ff28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.868313] ff48 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.871216] ff68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.874130] ff88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.877033] ffa8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.879932] ffc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 17.882829] ffe8 00000000 00000000 00000000 00000000 00000000 00000000 00000018 00000000
[ 17.885732] 0008* 0080000a 00000000 00000000 00000000 00000000 00000000 fa000013 00000000
[ 17.921296] usb 1-1.4: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10
[ 17.921967] 01c8 00800002 00000000 00000000 00000000 00000000 00000000
[ 17.923503] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 17.923512] usb 1-1.4: Product: USB Keyboard
[ 17.925828] fae00013
[ 17.927326] usb 1-1.4: Manufacturer:
[ 17.929598] 00000000
[ 17.934596] 01e8 00800002 00000000 00000000 00000000 00000000 00000000 faf00013 00000000
[ 17.937337]
[ 17.937337] X6: 0xffff800012b338f4:
[ 17.941763] 36f4 00000000 00000000 00000000 00000000 00000000 14100000 ffff8000 12b33844
[ 17.943376] input: USB Keyboard as /devices/platform/fe380000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:04D9:1603.0003/input/input3
[ 17.944862] 3714 ffff8000 00000004 00000000 00000000 00000000 05e58c00 ffff0000 00000000
[ 17.950632] 3734 00000000 110c9a6a ffff8000 00000000 00000000 00000000 00000000 00000001
[ 17.954294] 3754 00000000 12b337c0 ffff8000 105bab78 ffff8000 12b337c0 ffff8000 105bab88
[ 17.958036] 3774 ffff8000 60000085 00000000 119828e8 ffff8000 00ff1000 ffff0000 ffffffff
[ 17.961888] 3794 ffffffff 11a81b40 ffff8000 12b337c0 ffff8000 105bab88 ffff8000 12b337e0
[ 17.965836] 37b4 ffff8000 00000000 00000000 12b33800 ffff8000 10591b08 ffff8000 05dd1000
[ 17.969849] 37d4 ffff0000 1198f2d8 ffff8000 00000000 00000000 00000000 00000000 12b338f4
[ 17.973971] 37f4 ffff8000 1198f2d8 ffff8000 12b33850 ffff8000 1059538c ffff8000 00000000
[ 17.978183] 3814 00000000 05dd1000 ffff0000 05dd1000 ffff0000 00000000 00000000 12b338f4
[ 17.982514] 3834 ffff8000 0000ea60 00000000 12b33860 00000000 3874b000 a58548e3 12b338b0
[ 17.986931] 3854 ffff8000 1059552c ffff8000 00000000 00000000 00000000 00000000 05dd1000
[ 17.991419] 3874 ffff0000 00000000 00000000 00000001 00000000 00000000 00000000 110c9a6a
[ 17.995951] 3894 ffff8000 00000000 00000000 00000000 00000000 05dd1000 ffff0000 12b338c0
[ 18.000527] 38b4 ffff8000 10595b34 ffff8000 12b33900 ffff8000 10595c2c ffff8000 00000000
[ 18.004932] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Keyboard [ USB Keyboard] on usb-fe380000.usb-1.4/input0
[ 18.005211] 38d4 00000000 05dd1000 ffff0000 11a9a1b0 ffff8000 00000000 00000000 12b33920
[ 18.015373] 38f4* ffff8000 3874b000 a58548e3 12b33930 ffff8000 10596d18 ffff8000 00000000
[ 18.020842] 3914 00000000 05dd1000 ffff0000 11a9a1b0 ffff8000 05dd1000 ffff0000 12b339a0
[ 18.025331] input: USB Keyboard System Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:04D9:1603.0004/input/input4
[ 18.026420] 3934 ffff8000 10596bb0 ffff8000 00000000 00000000 05dd8000 ffff0000 05dd0800
[ 18.038369] 3954 ffff0000 05dd1000 ffff0000 05dd80b0 ffff0000 00000001 00000000 00000000
[ 18.044718] 3974 00000000 00000000 00000000 00000000 00000000 00000001 00000000 12b339a0
[ 18.051138] 3994 ffff8000 10596b94 ffff8000 12b33a40 ffff8000 10596f68 ffff8000 00000000
[ 18.057508] 39b4 00000000 05dd0800 ffff0000 11a9a1b0 ffff8000 00000001 00000000 00000000
[ 18.063776] 39d4 00000000 00000000 00000000 05dd8000 ffff0000 05dd0828 ffff0000 00000000
[ 18.069964] 39f4 00000000 00000001 00000000 12b33a40 00000000 00000000 00000000 00000000
[ 18.076093] 3a14 00000000 00000000 00000000 11a9a1b0 ffff8000 00000000 00020000 001f0100
[ 18.082203] 3a34 00000000 3874b000 a58548e3 12b33ab0 ffff8000 10596fc4 ffff8000 05e58800
[ 18.087621] input: USB Keyboard Consumer Control as /devices/platform/fe380000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:04D9:1603.0004/input/input5
[ 18.088357] 3a54 ffff0000 05dd0800 ffff0000 00000001 00000000 00fcb800 ffff0000 00fcb810
[ 18.095518] hid-generic 0003:04D9:1603.0004: input,hidraw3: USB HID v1.10 Device [ USB Keyboard] on usb-fe380000.usb-1.4/input1
[ 18.100940] 3a74 ffff0000 00000000 00000000 119ce148 ffff8000 00000004 00000000 11a7ee80
[ 18.113921] 3a94 ffff8000 00000000 00000000 fffffff4 00000000 0000001e 00000001 12b33ac0
[ 18.120448] 3ab4 ffff8000 10597258 ffff8000 12b33af0 ffff8000 105972b8 ffff8000 00000000
[ 18.127023] 3ad4 00000000 05e58800 ffff0000 00fcb810 ffff0000 05e58c00 ffff0000 12b33b20
[ 18.133599]
[ 18.133599] X9: 0xffff8000105bab78:
[ 18.145417] a978 8b234083 b900007f d50332bf f9400404 11700023 11002063 32090042 8b234083
[ 18.152097] a998 b9000062 d50332bf f9400400 11700021 11003021 8b214001 b900003f 52800000
[ 18.158787] a9b8 d50323bf d65f03c0 128002a0 17fffffd d503245f aa1e03e9 d503201f d503233f
[ 18.165539] a9d8 a9be7bfd d2800003 910003fd a90153f3 aa0003f4 2a0103f3 2a1303e0 f0ffd962
[ 18.172315] a9f8 d0009941 91189042 9105e021 97ecbe88 f9401281 2a1303e0 97ecbbad 52800000
[ 18.179126] aa18 a94153f3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f
[ 18.185985] aa38 a9bc7bfd 910003fd a90153f3 aa0403f4 a9025bf5 2a0303f5 53037c23 f9001bf7
[ 18.192920] aa58 f9400804 f9406817 b4000064 f9400885 b5000665 72001076 54000160 12800000
[ 18.199958] aa78 528010d6 b9000280 2a1603e0 a94153f3 a9425bf5 f9401bf7 a8c47bfd d50323bf
[ 18.207022] aa98 d65f03c0 b50004c4 f94006e0 93407c42 91600042 93407ea1 d1000421 8b020000
[ 18.213992] aab8 ea01001f 54000080 528010f6 b900029f 17ffffee 710012bf 54000101 b9400002
[ 18.220818] aad8 d50331bf 2a0203e0 ca000000 b5000000 b9000282 17ffffe5 71000abf 54000121
[ 18.227602] aaf8 97ffff8a 12003c01 d50331bf 92403c00 ca000000 b5000000 b9000281 17ffffdb
[ 18.234410] ab18 710006bf 54fffd21 97ffff7c 12001c01 d50331bf 92401c00 17fffff6 b94142f6
[ 18.241255] ab38 350004f6 39438013 53111063 53140821 12002c42 2a020022 510006a0 2a135073
[ 18.248000] ab58 2a020273 6a13001f 54fffb01 f9400880 b50001e0 52800141 aa1703e0 94000969
[ 18.254602] ab78* 710012bf 54000181 f94002e0 8b130013 b9400273 d50331bf 2a1303e0 ca000000
[ 18.261148] ab98 b5000000 b9000293 17ffffb8 52800161 17fffff2 71000abf 54000081 f94002e0
[ 18.267751] abb8 8b130000 17ffffcf 710006bf 54fff7e1 f94002e0 8b130000 17ffffd4 52800016
[ 18.274416] abd8 17ffffaa aa1e03e9 d503201f d503233f 8b214000 b9400000 d50331bf 2a0003e1
[ 18.281102] abf8 ca010021 b5000001 d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f
[ 18.287821] ac18 a9bb7bfd 910003fd a90153f3 9100c013 a9025bf5 a90363f7 a9046bf9 f9402416
[ 18.294623] ac38 f9400417 f9402ac0 f94066f9 b5000160 f94022c1 b4000081 aa1303e0 d63f0020
[ 18.301502] ac58 14000006 f9401ec1 aa1303e0 d63f0020 f9401ac1 b5ffff21 f94006e0 52800a01
[ 18.308453] ac78 f0005898 91031318 d280003a 97ffffd6 d3452014 35000194 f9402ac1 b4000321
[ 18.315443] ac98 aa1303e0 d63f0020 a94153f3 a9425bf5 a94363f7 a9446bf9 a8c57bfd d50323bf
[ 18.322350] acb8 d65f03c0 5ac00295 5ac012b5 9ad52340 0a200294 f9406ae0 93407ea1 97ecc86c
[ 18.329123] acd8 34000060 97eca4d3 17ffffeb 2a1503e2 aa1803e1 aa1903e0 941da8e0 17ffffe6
[ 18.335848] acf8 f94026c1 17ffffe7 d503245f aa1e03e9 d503201f d503233f a9bd7bfd 52800901
[ 18.342472] ad18 910003fd a90153f3 91004014 f90013f5 f9403e93 f9400660 97ffffab 120c0415
[ 18.348997] ad38 f9400660 52800781 97ffffa7 714c02bf 54000081 12001401 7100403f 54000060
[ 18.355475] ad58 52800020 b9014260 f8548260 97ff728d f8548260 97ff732a f9406a60 97eccb3b
[ 18.362057]
[ 18.362057] X10: 0xffff000005dd9a1c:
[ 18.373849] 981c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.380407] 983c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.386928] 985c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.393281] 987c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.463598] 9a1c* 00000079 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.468051] 9a3c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.472389] 9a5c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.476589] 9a7c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.480651] 9a9c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.484587] 9abc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.488373] 9adc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.492047] 9afc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.495573] 9b1c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.498957] 9b3c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.502223] 9b5c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.505362] 9b7c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.508353] 9b9c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.511199] 9bbc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.513920] 9bdc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.516487] 9bfc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 18.518910]
[ 18.518910] X19: 0xffff800014100000:
[ 18.522286] fe00
[ 19.653617] vendor storage:20190527 ret = -1
[ 42.560216] random: crng init done
[ 77.256818] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 77.258824] rcu: 3-…0: (2 ticks this GP) idle=a0a/1/0x4000000000000000 softirq=28/28 fqs=6000
[ 77.261327] (detected by 1, t=18002 jiffies, g=-919, q=4)
[ 77.263614] Task dump for CPU 3:
[ 77.265744] task:kworker/u12:2 state:R running task stack: 0 pid: 144 ppid: 2 flags:0x0000002a
[ 77.268830] Workqueue: events_unbound deferred_probe_work_func
[ 77.271616] Call trace:
[ 77.274125] __switch_to+0xdc/0x148
[ 77.276805] pci_scan_bridge_extend+0x488/0x54c
[ 77.279672] pci_scan_child_bus_extend+0x2c4/0x300
[ 77.282626] pci_scan_child_bus+0x20/0x2c
[ 77.285533] pci_scan_root_bus_bridge+0x9c/0xd4
[ 77.288552] pci_host_probe+0x28/0xb0
[ 77.291534] rockchip_pcie_really_probe+0x150/0x164
[ 77.294728] rockchip_pcie_probe+0x304/0x360
[ 77.297909] platform_drv_probe+0x60/0xb0
[ 77.301115] really_probe+0x2dc/0x46c
[ 77.304332] driver_probe_device+0x138/0x148
[ 77.307675] __device_attach_driver+0xd8/0x114
[ 77.311115] bus_for_each_drv+0xa4/0xcc
[ 77.314560] __device_attach+0xdc/0x170
[ 77.318057] device_initial_probe+0x20/0x2c
[ 77.321649] bus_probe_device+0x3c/0xa0
[ 77.325273] deferred_probe_work_func+0xe0/0xf4
[ 77.329045] process_one_work+0x1e0/0x298
[ 77.332831] process_scheduled_works+0x4c/0x50
[ 77.336712] worker_thread+0x1f8/0x27c
[ 77.340593] kthread+0xf8/0x108
[ 77.344453] ret_from_fork+0x10/0x30
I decided to take another Samsung EVO 980 NVMe SSD, which I happened to have, and try to boot from it. And the system booted from it.
It looks like the Kingspec NVMe SSD NX Series is not suitable, although Manjaro and Armbian were loaded from it.
Thank you all very much!
