Rock 5a/b irradium (based on crux linux)
irradium - source based Linux distribution CRUX adhering to ideology keep it simple, has its own package system , also supports the port system .
installation README.TXT
kernel 6.8.0-rc1
irradium-3.7-aarch64-core-rock_5b-6.8.0-rc1-build-20240128.img.zst
irradium-3.7-aarch64-core-rock_5b-6.8.0-rc1-build-20240128.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.8.0-rc1-build-20240128.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.8.0-rc1-build-20240128.img.zst.sha256
kernel 6.1.43
irradium-3.7-aarch64-core-rock_5b-6.1.43-build-20240421.img.zst
irradium-3.7-aarch64-core-rock_5b-6.1.43-build-20240421.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.1.43-build-20240421.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.1.43-build-20240421.img.zst.sha256
kernel 6.1.43
irradium-3.7-aarch64-core-rock_5a-6.1.43-build-20240421.img.zst
irradium-3.7-aarch64-core-rock_5a-6.1.43-build-20240421.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5a-6.1.43-build-20240421.img.zst
irradium-3.7-aarch64-xfce-rock_5a-6.1.43-build-20240421.img.zst.sha256
kernel 6.1.43
for the panthor driver to work, you need to add rockchip-rk3588-panthor-gpu to overlays=rockchip-rk3588-opp-oc-24ghz rockchip-rk3588-panthor-gpu in the uEnv.txt file to make it work.
irradium-3.7-aarch64-core-rock_5b-6.1.43-build-20240427.img.zst
irradium-3.7-aarch64-core-rock_5b-6.1.43-build-20240427.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.1.43-build-20240427.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.1.43-build-20240427.img.zst.sha256
kernel 6.1.43
irradium-3.7-aarch64-core-rock_5a-6.1.43-build-20240427.img.zst
irradium-3.7-aarch64-core-rock_5a-6.1.43-build-20240427.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5a-6.1.43-build-20240427.img.zst
irradium-3.7-aarch64-xfce-rock_5a-6.1.43-build-20240427.img.zst.sha256
@mara
I tried this image, on typing ā€˜ifconfig’ I only see the lo interface, should’t it have eth0 out of the box? Are there issues with the driver?
That’s right, it should, my board failed almost immediately, so everything was displayed correctly on the orange pi 5 plus.
you need to look at dmesg and lsmod, maybe there will be a hint there
kernel 6.1.84
mirror 1, mirror 2, mirror 3
irradium-3.7-aarch64-core-rock_5b-6.1.84-build-20241229.img.zst
irradium-3.7-aarch64-core-rock_5b-6.1.84-build-20241229.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.1.84-build-20241229.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.1.84-build-20241229.img.zst.sha256
Mara mara mara… Dona… Hey … any desktop environment screenshto for us to see what this Irradium thing is about?
this is the same CRUX only for aarch64 and riscv64.
rock 5a
kernel 6.1.84
irradium-3.7-aarch64-core-rock_5a-6.1.84-build-20241229.img.zst
irradium-3.7-aarch64-core-rock_5a-6.1.84-build-20241229.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5a-6.1.84-build-20241229.img.zst
irradium-3.7-aarch64-xfce-rock_5a-6.1.84-build-20241229.img.zst.sha256
rock 5b
kernel 6.13.0-rc5
irradium-3.7-aarch64-core-rock_5b-6.13.0-rc5-build-20241231.img.zst
irradium-3.7-aarch64-core-rock_5b-6.13.0-rc5-build-20241231.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.13.0-rc5-build-20241231.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.13.0-rc5-build-20241231.img.zst.sha256
Any chance you make this for cm5?
yes, but it won’t be possible to test it.
But I can. Theres only one thing you need to consider. (In two weeks or so but I can give u feedback).
For the cm5 radxa made two images. One works only for their oficial carrier board (that I dont own cant test) the other works pretty much for all.
Radxa CM5 RPI CM4 IO - This is the one… I suggest you to craft. Otherwise it will boot but no usb devices will be detectes (on the other version).
prepared images image_build_kit
rock 5b
kernel 6.13.0
irradium-3.7-aarch64-core-rock_5b-6.13.0-build-20250124.img.zst
irradium-3.7-aarch64-core-rock_5b-6.13.0-build-20250124.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5b-6.13.0-build-20250124.img.zst
irradium-3.7-aarch64-xfce-rock_5b-6.13.0-build-20250124.img.zst.sha256
rock 5a
kernel 6.13.0
irradium-3.7-aarch64-core-rock_5a-6.13.0-build-20250125.img.zst
irradium-3.7-aarch64-core-rock_5a-6.13.0-build-20250125.img.zst.sha256
irradium-3.7-aarch64-xfce-rock_5a-6.13.0-build-20250125.img.zst
irradium-3.7-aarch64-xfce-rock_5a-6.13.0-build-20250125.img.zst.sha256
