[ 71.248] X.Org Video Driver: 25.2
[ 71.248] X.Org XInput driver : 24.4
[ 71.250] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 71.258] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 71.428] (==) Matched modesetting as autoconfigured driver 0
[ 71.428] (==) Matched fbdev as autoconfigured driver 1
[ 71.428] (==) Assigned the driver to the xf86ConfigLayout
[ 71.429] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 71.453] Module class: X.Org Video Driver
[ 71.453] ABI class: X.Org Video Driver, version 25.2
[ 71.460] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 71.508] (II) modeset(0): using drv /dev/dri/card0
[ 71.511] (II) Loading sub module "glamoregl"
[ 71.511] (II) LoadModule: "glamoregl"
[ 71.511] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 71.597] (II) Module glamoregl: vendor="X.Org Foundation"
[ 76.140] (II) modeset(0): glamor X acceleration enabled on Mali-G52 r1 (Panfrost)
[ 76.140] (II) modeset(0): glamor initialized
[ 76.765] (II) modeset(0): [DRI2] Setup complete
[ 76.766] (II) modeset(0): [DRI2] DRI driver: rockchip
[ 76.766] (II) modeset(0): [DRI2] VDPAU driver: rockchip
[ 76.774] (II) Initializing extension DRI3
[ 77.875] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 77.875] (II) Initializing extension XFree86-DRI
[ 77.875] (II) Initializing extension DRI2
[ 78.350] Module class: X.Org XInput Driver
[ 78.350] ABI class: X.Org XInput driver, version 24.4
[ 78.350] (II) Using input driver 'libinput' for 'rk805 pwrkey'
[ 90.347] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[ 90.383] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[ 90.406] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[ 119.190] (II) No input driver specified, ignoring this device.
[ 119.239] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
I was able to boot on Rock 3C using the latest image for Rock 3A. Everything seems functional, except the fact that thereâs no internet. wlan adapter is not recognized, and even though ethernet is recognized (and i can see the mac address), it cannot establish a connection. How can I make it work?
I thought 3C has the same Ethernet as 3A, so it wonât be a problem, but it seems that there is some incompatibility because of the different chips (RK3566 vs RK3568). Is there a way to resolve this?
Iâm able to use the internet only from my phone via USB Tethering, but not from LAN, and definitely not from WLAN (which is not recognized)
I thought of this yesterday and already did it. And I did it again just now, and got the same result as yesterday: It doesnât boot at all (not even a boot screen), the cpu is getting hot (the pwm fan even started spinning).
I guess it needs a proper device tree, which i canât find.
Iâve added the dtb file to /boot/dtbs/6.6.0-rc5/rockchip/, changed the uEnv.txt file.
Now, there are some improvements, but thereâs still no internet. The User LED now blinks (as it should). It shows me that the connection on ethernet is established, but no internet. On the port, only the green led is on, the orange one is off. Wifi adapter is finally recognized, I can even see the wifi networks from my house, but when Iâm trying to connect to them it disconnects right away (not even the password request form is shown).
From dmesg:
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.3668] NetworkManager (version 1.44.2) is starting⌠(boot:ac5ff9cb-63a8-4f9b-a5dc-acf5f0206440)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.3670] Read config: /etc/NetworkManager/NetworkManager.conf (etc: 00-dhcp-client.conf, 00-rc-manager.conf)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4042] manager[0x148c1aa0]: monitoring kernel firmware directory â/lib/firmwareâ.
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4123] hostname: hostname: couldnât get property from hostnamed
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4133] hostname: static hostname changed from (none) to ârock-3aâ
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4227] dns-mgr: init: dns=default,systemd-resolved rc-manager=file
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4254] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/platform/fe2c0000.mmc/mmc_host/mmc2/mmc2:0001/mmc2:0001:1/ieee80211/phy0/rfkill1) (driver brcmfmac)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4262] manager[0x148c1aa0]: rfkill: Wi-Fi hardware radio set enabled
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4263] manager[0x148c1aa0]: rfkill: WWAN hardware radio set enabled
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4593] Loaded device plugin: NMOvsFactory (/usr/lib64/NetworkManager/1.44.2/libnm-device-plugin-ovs.so)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4652] Loaded device plugin: NMWifiFactory (/usr/lib64/NetworkManager/1.44.2/libnm-device-plugin-wifi.so)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.4711] Loaded device plugin: NMAtmManager (/usr/lib64/NetworkManager/1.44.2/libnm-device-plugin-adsl.so)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5083] Loaded device plugin: NMBluezManager (/usr/lib64/NetworkManager/1.44.2/libnm-device-plugin-bluetooth.so)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5116] Loaded device plugin: NMWwanFactory (/usr/lib64/NetworkManager/1.44.2/libnm-device-plugin-wwan.so)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5131] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5133] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5136] manager: Networking is enabled by state file
Oct 15 20:57:47 rock-3a dbus-daemon[895]: [system] Activating service name=âorg.freedesktop.nm_dispatcherâ requested by â:1.2â (uid=0 pid=927 comm="/usr/sbin/NetworkManager") (using servicehelper)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5158] settings: Loaded settings plugin: keyfile (internal)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5432] dhcp: init: Using DHCP client âdhcpcdâ
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5444] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5500] device (lo): state change: unmanaged -> unavailable (reason âconnection-assumedâ, sys-iface-state: âexternalâ)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5521] device (lo): state change: unavailable -> disconnected (reason âconnection-assumedâ, sys-iface-state: âexternalâ)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5550] device (lo): Activation: starting connection âloâ (975b215d-c16b-438a-bc0d-f4221ee14e9a)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5578] device (eth0): carrier: link connected
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5592] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Oct 15 20:57:47 rock-3a sshd[947]: Server listening on 0.0.0.0 port 22.
Oct 15 20:57:47 rock-3a sshd[947]: Server listening on :: port 22.
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5653] device (eth0): state change: unmanaged -> unavailable (reason âconnection-assumedâ, sys-iface-state: âexternalâ)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5680] device (eth0): state change: unavailable -> disconnected (reason âconnection-assumedâ, sys-iface-state: âexternalâ)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5709] device (eth0): Activation: starting connection âeth0â (c491f5d5-871f-4ae4-a0d1-b09ffa7cdfc9)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5772] device (wlan0): driver supports Access Point (AP) mode
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5805] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 15 20:57:47 rock-3a NetworkManager[927]: [1697403467.5819] device (wlan0): state change: unmanaged -> unavailable (reason âmanagedâ, sys-iface-state: âexternalâ)
part 2 from 'messages'
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.1578] device (wlan0): set-hw-addr: set MAC address to A6:98:4E:2D:B1:7F (scanning)
Oct 15 20:57:48 rock-3a ntpd[960]: gps base set to 2023-06-25 (week 2268)
Oct 15 20:57:48 rock-3a ntpd[960]: switching logging to file /var/log/ntp
Oct 15 20:57:48 rock-3a dbus-daemon[895]: [system] Activating service name=âfi.w1.wpa_supplicant1â requested by â:1.2â (uid=0 pid=927 comm="/usr/sbin/NetworkManager") (using servicehelper)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.1756] bus-manager: acquired D-Bus service âorg.freedesktop.NetworkManagerâ
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.1964] ovsdb: disconnected from ovsdb
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.1970] device (lo): state change: disconnected -> prepare (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2008] device (lo): state change: prepare -> config (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2036] device (lo): state change: config -> ip-config (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2050] device (eth0): state change: disconnected -> prepare (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2069] device (eth0): state change: prepare -> config (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2084] device (eth0): state change: config -> ip-config (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2106] device (lo): state change: ip-config -> ip-check (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a dbus-daemon[895]: [system] Activating service name=âorg.freedesktop.ModemManager1â requested by â:1.2â (uid=0 pid=927 comm="/usr/sbin/NetworkManager") (using servicehelper)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2137] device (eth0): state change: ip-config -> ip-check (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2265] device (lo): state change: ip-check -> secondaries (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2272] device (eth0): state change: ip-check -> secondaries (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2279] device (lo): state change: secondaries -> activated (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2302] device (lo): Activation: successful, device activated.
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2326] device (eth0): state change: secondaries -> activated (reason ânoneâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2340] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.2349] device (eth0): Activation: successful, device activated.
Oct 15 20:57:48 rock-3a dbus-daemon[895]: [system] Activated service âorg.freedesktop.ModemManager1â failed: Launch helper exited with unknown return code 127
Oct 15 20:57:48 rock-3a dbus-daemon[895]: [system] Successfully activated service âfi.w1.wpa_supplicant1â
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5049] device (wlan0): supplicant interface state: internal-starting -> disconnected
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5053] Wi-Fi P2P device controlled by interface wlan0 created
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5064] manager: (p2p-dev-wlan0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5074] device (p2p-dev-wlan0): state change: unmanaged -> unavailable (reason âmanagedâ, sys-iface-state: âexternalâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5094] device (wlan0): state change: unavailable -> disconnected (reason âsupplicant-availableâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:48 rock-3a NetworkManager[927]: [1697403468.5113] device (p2p-dev-wlan0): state change: unavailable -> disconnected (reason ânoneâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:49 rock-3a dbus-daemon[895]: [system] Activating service name=âorg.freedesktop.Accountsâ requested by â:1.5â (uid=0 pid=1013 comm="/usr/bin/lightdm") (using servicehelper)
Oct 15 20:57:49 rock-3a dbus-daemon[895]: [system] Activating service name=âorg.freedesktop.PolicyKit1â requested by â:1.6â (uid=0 pid=1024 comm="/usr/libexec/accounts-daemon") (using servicehelper)
Oct 15 20:57:49 rock-3a polkitd[1033]: Started polkitd version 123
Oct 15 20:57:50 rock-3a dbus-daemon[895]: [system] Successfully activated service âorg.freedesktop.PolicyKit1â
Oct 15 20:57:50 rock-3a accounts-daemon[1024]: started daemon version 22.08.8
Oct 15 20:57:50 rock-3a dbus-daemon[895]: [system] Successfully activated service âorg.freedesktop.Accountsâ
Oct 15 20:57:54 rock-3a elogind-daemon[908]: New session c1 of user lightdm.
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.0943] policy: auto-activating connection âTP Link 2.4Gâ (c8ba1867-4941-405a-aa80-78a4a7422b94)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.0968] device (wlan0): Activation: starting connection âTP Link 2.4Gâ (c8ba1867-4941-405a-aa80-78a4a7422b94)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.0975] device (wlan0): state change: disconnected -> prepare (reason ânoneâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.0986] manager: NetworkManager state is now CONNECTING
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6106] device (wlan0): set-hw-addr: reset MAC address to 50:5A:65:27:0C:7D (preserve)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6136] device (wlan0): state change: prepare -> config (reason ânoneâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6163] device (wlan0): Activation: (wifi) access point âTP Link 2.4Gâ has security, but secrets are required.
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6164] device (wlan0): state change: config -> need-auth (reason ânoneâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6176] sup-iface[ff76456fe5a6d743,0,wlan0]: wps: type pbc startâŚ
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6192] device (wlan0): supplicant interface state: disconnected -> inactive
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6192] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> inactive
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6198] device (wlan0): state change: need-auth -> failed (reason âno-secretsâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:55 rock-3a NetworkManager[927]: [1697403475.6212] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1542] device (wlan0): set-hw-addr: set MAC address to 3A:9E:3D:DB:B4:8D (scanning)
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1599] device (wlan0): supplicant interface state: inactive -> disconnected
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1600] device (p2p-dev-wlan0): supplicant management interface state: inactive -> disconnected
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1616] device (wlan0): state change: failed -> disconnected (reason ânoneâ, sys-iface-state: âmanagedâ)
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1792] device (wlan0): supplicant interface state: disconnected -> inactive
Oct 15 20:57:56 rock-3a NetworkManager[927]: [1697403476.1793] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> inactive
Oct 15 20:57:56 rock-3a dbus-daemon[1064]: [session uid=620 pid=1062] Activating service name=âorg.a11y.Busâ requested by â:1.0â (uid=620 pid=1056 comm="/usr/bin/lightdm-gtk-greeter")
Oct 15 20:57:56 rock-3a dbus-daemon[1064]: [session uid=620 pid=1062] Successfully activated service âorg.a11y.Busâ
Oct 15 20:58:02 rock-3a NetworkManager[927]: [1697403482.7822] manager: startup complete
Oct 15 20:58:02 rock-3a NetworkManager[927]: [1697403482.7874] device (wlan0): supplicant interface state: inactive -> scanning
Oct 15 20:58:02 rock-3a NetworkManager[927]: [1697403482.7875] device (p2p-dev-wlan0): supplicant management interface state: inactive -> scanning
Oct 15 20:58:04 rock-3a elogind-daemon[908]: Removed session c1.
Update: Iâm able to connect to a wifi network now. Only by creating a new connection and manually inserting SSID and password. Not by selecting the network from the panel.
Still no internet on ethernet.
Well, after playing with Slarm64 on Rock 3C (no ethernet connection from the very begining), now the ethernet is messed up. It doesnât work even if i flash a clean official image (Debian 11). It tries to connect to the router, but without any success. I tried to connect it to a PC, using static a ip and it also doesnât want to connect.
