Nasca
21
tested with these cmds:
arecord -D "plughw:4,0" -r 48000 -d 5 -f S16_LE -c 2 -t wav test.wav
aplay -D "plughw:4,0" -f S16_LE -r 48000 -c 1 test.wav
and on Armbian system, you need set alsamixer manually, on our debian system you need not set it manually.
Erez8
22
Hi
I’m trying to compile armbian with the relevant changes.
Did you push the change only to kernel 6.1.x?
what about kernels 6.12 or 6.13?
Nasca
23
which branch did you refer to ?
Erez8
24
Branch: rk-6.1-rkr5.1
Repo: https://github.com/armbian/linux-rockchip
Did this change is already relevant for newer kernels?
Nasca
25
yes, you need to update the kernel to the latest
