So…using the pinout doc, which ones are you looking to use ? Are they anabled with an overlay or are you using all defaults ? https://wiki.radxa.com/Rock4/hardware/gpio
I’ve install libraries only… I’ve not change any settings; i would be testing if pin work correctly.
I’ve connected an simple LED(with resistor in series…) at PIN40 / GPIO4_A7 / GPIO135 and by Linux shell put the command below:
sudo mraa-gpio set 40 1 (but GPIO don't change the status)
After that I’ve tried with python IDLE3 shell but both libraries not exists.
have you any suggestion to help me?.. I’m at first experience with arm board with Linux.
libmraa is a C library, to work correctly in python, you must also build rhe python wrapper and install it. The wrapper is automatically build if you installed the python development libraries if I remember correctly.
I have two Rock Pi 4c plus units. I ordered them to compare to the Raspberry Pi 4. It has been a frustrating experience. I ordered the plus because I assume it would be better than the 4C, wrong. Then there is the issue of Debian Bullseye. It doesn’t come with wifi enabled. The KWallet doesn’t accept network passwords. Packages such as realVNC don’t load properly. I have been monitoring other problems with this board and there are many, I would really like to send these back and have them replaced with something that is more Linux friendly. I know this is off topic but I had to vent somewhere.
