I never used the official images and don’t have a Rock 5C so I can’t help further. If you must use them, maybe try not upgrading the packages next time, I don’t have any other ideas.
You can try this tip:
- after you follow the steps above, use your finger to spin the fan clockwise
Sometimes there is not enough torque to start spinning.
- Boot up the board and check the state:
cat /sys/class/thermal/cooling_device?/type
cpufreq-cpu0
cpufreq-cpu4
cpufreq-cpu6
devfreq-dmc
devfreq-fb000000.gpu-mali
pwm-fan
pwm-fan device in my kernel is 5:
cat /sys/class/thermal/cooling_device5/cur_state
4
If I set the state to 1 (not enough torque, it stops spinning) and later put it to 4, the fan won’t start spinning. I have to help it, and then it keeps spinning. This is the reason i still have passive cooling.
PS: my fan (no radxa logo) and board are the early ones.
Comparing this fan (Rock 5B , not the plus) to a Rock 5C fan, Rock 5C fan screams like an F1 V10 fully throttled.
