OpenSUSE Tumbleweed uses a fairly “upstream” kernel, afaik, but in the meantime I am trying out other distributions to see what the experience will be like and that is quite enjoyable in itself. I have an Ethernet cable plugged in so I can wait for the wireless stuff.
The thing that worried me was that I replaced the stock pigtails with shorter ones. I’ve never done that before so I wasn’t sure that I had assembled everything correctly. As Tumbleweed blocked the interfaces there was no way of knowing if the hardware was working properly.
But trying other distributions (Debian and Armbian) erased that worry. The hardware works fine and communicates with the router and Bluetooth peripherals the way they are supposed to. In fact, the reception of the wireless is the best I’ve ever had on a device. Very happy about that.
So I guess I can wait for now and report on the progress as it happens on the openSUSE side of things.
Hello Hukka,
I was able to install Opensuse Tumbleweed . Pcie NVME disk is recognised.
Iwlwifi does not load iwl-firmware properly. I am now with kernel 6.9 rc7.
Do you have more information?
Regards
Uli
Well, all I need right now is that the switch to turn off the hard block should be in kernel 6.9. If you’re using the RC then it should be there. I don’t know more than that at this time.
Hi, I’m on the newest OpenSUSE Tumbleweed with kernel version 6.11 and face the same issue. Have you happened to find a resolution? rfkill list all still shows the following and doesn’t seem to make the setting tweakable by user (i.e. “soft blocked”)
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
In Tumbleweed Arm I’m still using wireless keyboard and mouse (with a USB dongle) and an ethernet cable, sorry to say. Neither bluetooth nor wifi with the AX200 module. I can wait.
Riek’s Ubuntu variant has both bluetooth and wifi working.
Testing the new Armbian release (24.11) later this week.
Thank you for your reply. So based on your thread, it seems Debian-based systems are working. I’ll try Debian and Ubuntu tomorrow. Hopefully it works and I don’t have to return my new laptop.
Joshua Riek has done a lot of work to make Arm-based computers a valid option for a lot of people. His variant of Ubuntu has better support for Arm hardware than what it is based on.
The same can be said about the Armbian releases. A lot of effort has been put on making the Arm architecture almost as easy to use as the (more common) Intel and AMD offerings.
The OS releases from Radxa are well made but use a slower (more conservative) release cycle, which offers better hardware compatibility but without the newest drivers.
None of above can be designated “official” Debian or Ubuntu releases. Using one of the above options will give you a computer that you can trust, but all of them have added value compared to the base distributions. They are all tweaked for Arm hardware and thus not quite “standard”. Keep that in mind.
I don’t have a preference when choosing between debian- arch- or rpm-based distributions. I use a bit of everything and distrohop if I need to. All my computers are Arm-based, though.
Thank you for your reply. I see what’s going on rn. I actually just tried Debian and it doesn’t work. I also discovered the previous kernel fix was for rockchip only so is unlikely to go to my AMD cpu laptop I guess?
I’ve done some extra search during the day and it is evident now my problem was caused by some crappy, untweakable setting in BIOS. My best shot now is probably just insulate tape the two hardware lock pins.
I guess you are not using rock5b because witth kernel after 6.11 the output of rfkill list should be like
$ rfkill list
0: rfkill-pcie-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: rfkill-m2-bt: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
