Thermal throttling is configured by default in Rock Pi S’ device tree:
Rock Pi S DTS
rk3308k thermal zones overrides
rk3308 thermal zones
Linux thermal framework device tree docs
I did not perform long torture tests but run sbc-bench a few times.
Here http://ix.io/1UmF you can find an example result of unit overclocked to 1.2GHz with default (rk3308k) trip points. At the bottom you can see it throttled when running cpuminer at ~60C.
As a side note: I don’t know if Rock Pi S correctly uses rk3308k thermal zones as I think (not being sure) it uses rk3308 and not rk3308k.
When making Armbian support I changed that in device tree so that it throttles at higher temps.
