Following @RadxaYuntian’s advices, I come up with the following overlay :
/dts-v1/;
/plugin/;
compatible = "radxa,zero", "amlogic,g12a";
fragment@0 {
target-path = "/";
__overlay__ {
gpio-poweroff {
compatible = "gpio-poweroff";
/* gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; */
gpios = <&gpio_ao 3 1>;
status = "okay";
I’ve removed the includes from w1-gpioao-3.dts, giving the raw pin number as found in the included file, so that it’s easier to compile.
The overlay compiles and loads successfully. From the latest @theophile’s comments, I believe it should perform as intended. I cannot confirm sin ce I can’t monitor the voltage on GPIOAO_3 (physical pin 7). I’ll report here if I get updates on this. Anyone able to test this overlay before me would be welcome to tell !
How would one adapt this to work with a Rock Pi E or similar rk3328 based device?
My current failed attempt is this:
/dts-v1/;
/plugin/;
compatible = "rockchip,rk3328";
fragment@0 {
target-path = "/";
__overlay__ {
gpio-poweroff {
gpios = <&gpio1 24 0>;
timeout-ms = <20000>;
force;
dtc -I dts -O dtb -f rk3328-poweroff-gpio1-24.dts -o /boot/dtb/rockchip/overlay/rk3328-poweroff-gpio1-24.dtbo
/boot/armbianEnv.txt:
overlays=rk3328-poweroff-gpio1-24
No output on gpio24 on shutdown complete.
Couple things. First, the overlay isn’t enough. You also need a kernel that has CONFIG_POWER_RESET_GPIO enabled, and depending on what kernel you’re using, you may need to either modify /drivers/firmware/psci/psci.c to comment out the ‘pm_power_off = psci_sys_poweroff’ line, or adapt these patches.
Second, it might be worth checking to see if the rk3328 can run a Hardkernel odroid kernel, as Hardkernel has a similar implementation of this already built in. I think the odroid go has an rk3326. I’m not sure how similar they are so maybe this is a non-starter, but probably worth a look just in case.
