Fixing U-boot to support boot from NVMEs
Cool @Human_USB . USB TTL is almost necessary for ARM boards I have realized.
The dupont cables that I have are 24 AWG 70 cm length (like here), so your 22 AWG ones should be ok.
FTDI works fine - comX on the motherboard not works with 1500k
Hi.First of all I would like to tell you that I managed to work with the system from nvme.
Now, is it possible to overclocking? And is it advisable? I have the massive heatsink, but I don’t have a fan. I have the device, with all the USB ports busy, including a speaker on the top USB 3.0, and trying to work with a printer (which I still couldn’t get to work) the device gets quite hot.
My question regarding whether it can be done and if it is advisable to do overclocking in Armbiam, is because I notice that the Chromium browser is not fluid enough (for example, when wanting to deploy functions with the right button on links, it takes to load the options) and I assumed that that would be solved by overclocking, or maybe it’s a Chromium problem?
