Fail to boot armbian images after spi bootloader upgrade
I managed to format my nvme SSD via my laptop (temporary replaced “windows 10 nvme” with the “rock pi nvme”, booted Linux via USB and format with Gparted. So far that’s working again.
Been searching the web this evening but still couldn’t find a solution.
Now I’m too fed up that the maker of this product doesn’t provide a solution, let alone respond to the issue. I contacted the shop where I bought the rock pi and asked what options are available to return the item…
Apparantely a new kernel has been released (see here). It might lead to a solution…
Hey @alotje
Could you try again with the latest Armbian Buster current image (with Linux 5.3.x)?
It worked for me when booting from Radxa eMMC + Armbian SD card. Only needed to change /boot/armbianEnv.txt and add fdtfile=rockchip/rk3399-rock-pi-4.dtb as specified in the other thread. First boot can take a bit of time though!
Can confirm that this still does NOT work. SPI flashed properly with latest loader and trust image, attempting to boot Buster Minimal Nightly from SD ends in failure.
GPT  signature is wrong
LoadTrust Addr:0x1800
LoadTrust Addr:0x1c00
LoadTrust Addr:0x2000
LoadTrust Addr:0x2400
LoadTrust Addr:0x2800
LoadTrust Addr:0x2c00
LoadTrust Addr:0x3000
LoadTrust Addr:0x3400
Addr:0x1800 No find trust.img!
LoadTrustBL error:-3
SecureMode = 0
SecureInit ret = 0, SecureMode = 0
Then it hangs. With no SD card in, it attempts to boot from the network.
UPDATE: Shorting the SPI clock to GND allows the SD Card to boot successfully.
UPDATE2: Erasing UBoot from SPI Flash will also allow the SD Card to boot successfully.
Can you (or someone else who has a UART console) show the output of the “printenv” and “help” commands from the latest version of u-boot SPI ? Or where can I see the sources from which it is going ? It seems there are several causes of the problem and they are related to different parts of the startup process (u-boot settings, user settings of the system being started, etc.).
By the way, for those who check different Armbian images, you need to take into account that the kernel 4 and 5 may need different settings of the name used by DTB.
I don’t have such hardware, so I might be wrong, but I would check to remove the u-boot (after writing the Armbian image) from the recorded SD or NVMe media. They may conflict with the SPI and interfere with the startup process.
I did this
apt-get install -y rockpi4b-rk-u-boot-latest
/usr/local/sbin/rockpi4b_upgrade_bootloader.sh
boot SDcard Armbian 4.4.198, and same Armbian 5.3.11
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2018-06-26, version: 1.14
CPUId = 0x0
ChipType = 0x10, 221
Spi_ChipId = ef4017
SpiBootInit:0
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 149915
SecureMode = 0
SecureMode = 0
stops here
I need other information. Turn off all media (SD NVMe etc.). Turn on the power and immediately stop running u-boot (press and hold the space bar). U-boot should stop and prompt for commands. Type printenv and press Enter. The result show here. So same for command “Help.” By the way, judging by the attached conclusion, the problem is not the correct u-boot (the system tries to take the u-boot from the SD card, but it is not correct).
Try to write to SD card image for TV box for aml-g12, configure dtb in (extlinux.conf) and check startup (there is initially no u-boot for rk3399 and the system should try to use SPI). The result show here.
the keyboard (usb) does not work in this mode
This is done from the PC where the UART console output is started (when the terminal starts to output data to the console). :slight_smile:
I understand correctly that you now have a bootloader in SPI with support for running different systems (including NVMe). ? Can you do a little checking ?
Show more UART console output if you disable all media (SD card, NVMe module and USB stick).
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
OUT
CPUId = 0x0
Spi_ChipId = ef4017
SpiBootInit:0
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 21717
SecureMode = 0
GPT vendor signature is wrong
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 1000
Load OK, addr=0x200000, size=0xef1e8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):0e7a845
NOTICE: BL31: Built : 16:13:46, Apr 17 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-2681-geb41d9a6ce (Nov 04 2019 - 09:32:53 +0000), Build: jenkins-linux-build-testing-2-85
Model: Rockchip RK3399 rockpi4b Board
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bdf000
Sysmem: init
I2c speed: 400000Hz
PMIC: RK808
vdd-center init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
Error: “rkimg_bootdev” not defined
Bootdev: mmc 1
MMC: no card present
mmc_init: -123, time 0
rockchip_get_bootdev: can’t find dev_desc!
[Vendor ERROR]:Invalid boot device type(0)
rockchip_get_boot_mode: dev_desc is NULL!
init_resource_list: dev_desc is NULL!
Can’t find file:logo.bmp
failed to display uboot logo
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot(‘CTRL+C’): 0
Device 0: unknown device
mmc_init: -95, time 26
starting USB…
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: failed to get usb phy
Port not available.
USB3: failed to get usb phy
Port not available.
USB4: Can’t get the usbphy register address
probe failed, error -6
USB5: Can’t get the usbphy register address
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
ethernet@fe300000 Waiting for PHY auto negotiation to complete… done
Speed: 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.1.149 (258 ms)
*** Warning: no boot file name; using ‘C0A80195.img’
Using ethernet@fe300000 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.149
Filename ‘C0A80195.img’.
Load address: 0x800800
Loading: T T T T T T T T T T
Oh, I see a number of interesting things in the log. :slight_smile: Try now the following check. Download, unpack and burn to USB flash drive (not SD card) any last image for TV boxes Armbian or LE for rk3399 (links are in these topics). Check in (/extlinux/extlinux.conf) DTB setting for rock-pi-4. Connect the USB stick and turn on the power. Log run show here. I think you should normally start the system c USB flash drive. After that, can solve the issue of starting the system with NVMe.
extlinux.conf
ABEL LibreELEC
LINUX /KERNEL
FDT /rk3399-rock-pi-4.dtb
APPEND boot=UUID=2211-5513 disk=UUID=a321c910-4860-4321-bec0-31d20884f00c quiet console=uart8250,mmio32,0xff1a0000 console=tty0
not boot, not find USB stick
I can not
Where did you get this version of the image ? This image is clearly not one of the links I gave you. And show the full log of the entire startup process (this is important).
my rockpi4 starting fine with SPI/NVME without SDcard, (also 5.x) both officiall or armbian, but if i put SDcard with armbian, it not starting when spi is flashed or 23,25 pin in not connect
my very bad english
(press and hold the space bar) not works, but this result with usb stick
In
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
OUT
CPUId = 0x0
ChipType = 0x10, 220
Spi_ChipId = ef4017
SpiBootInit:0
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 21728
SecureMode = 0
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
U-Boot 2017.09-2681-geb41d9a6ce (Nov 04 2019 - 09:31:57 +0000), Build: jenkins-linux-build-testing-2-85
Model: Rockchip RK3399 rockpi4a Board
PreSerial: 2
DRAM: 3.9 GiB
Sysmem: init
I2c speed: 400000Hz
PMIC: RK808
Bootdev: mmc 1
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
mmc_init: -95, time 27
Could not get mmc 0
mmc_init: -95, time 18
do_boot_rockchip: dev_desc is NULL!
=> printenv
arch=arm
baudrate=1500000
board=evb_rk3399
board_name=evb_rk3399
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_net_pci_enum=pci enum
boot_net_usb_start=usb start
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=nvme mmc1 mmc0 usb0 pxe dhcp
bootargs=storagemedia=sd androidboot.mode=sd
bootcmd=run distro_bootcmd;boot_android ${devtype} ${devnum};bootrkp;
bootcmd_dhcp=run boot_net_usb_start; run boot_net_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_nvme=dcache off;pci e;nvme scan;setenv devnum 0;run nvme_boot;
bootcmd_pxe=run boot_net_usb_start; run boot_net_pci_enum; dhcp; if pxe get; then pxe boot; fi
bootcmd_usb0=setenv devnum 0; run usb_boot
bootdelay=1
cpu=armv8
cpuid#=544e4d3237372e3030000000000d0008
devnum=0
devtype=mmc
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
ethaddr=4a:a4:83:ac:26:71
fdt_addr_r=0x08300000
fdt_overlay_addr_r=0x08200000
fdtcontroladdr=0xe9dc9c40
fdtfile=rockchip/rockpi-4a-linux.dtb
hw_conf_addr_r=0x00700000
kernel_addr_r=0x00280000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
nvme_boot=if nvme dev ${devnum}; then setenv devtype nvme; run scan_dev_for_boot_part; fi
partitions=uuid_disk=${uuid_gpt_disk};name=loader1,start=32K,size=4000K,uuid=${uuid_gpt_loader1};name=loader2,start=8MB,size=4MB,uuid=${uuid_gpt_loader2};name=trust,size=4M,uuid=${uuid_gpt_atf};name=boot,size=112M,bootable,uuid=${uuid_gpt_boot};name=rootfs,size=-,uuid=B921B045-1DF0-41C3-AF44-4C6F280D3FAE;
pxefile_addr_r=0x00600000
ramdisk_addr_r=0x0a200000
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}…; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing…; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing…; fi; done
scriptaddr=0x00500000
serial#=8e8c8db600c01d48
soc=rockchip
stderr=serial,vidconsole
stdout=serial,vidconsole
usb_boot=usb start; if usb dev ${devnum}; then setenv devtype usb; run scan_dev_for_boot_part; fi
vendor=rockchip
Environment size: 3110/32764 bytes
=> help
? - alias for ‘help’
base - print or set address offset
bdinfo - print Board Info structure
boot_android- Execute the Android Bootloader flow.
bootavb - Execute the Android avb a/b boot flow.
booti - boot arm64 Linux Image image from memory
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootrkp - Boot Linux Image from rockchip image type
bootz - boot Linux zImage image from memory
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dcache - enable or disable data cache
dhcp - boot image via network using DHCP/TFTP protocol
dm - Driver model low level access
dtimg - manipulate dtb/dtbo Android image
echo - echo args to console
editenv - edit environment variable
env - environment handling commands
exit - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls - list files in a directory (default /)
ext4size- determine a file’s size
false - do nothing, unsuccessfully
fastboot- use USB or UDP Fastboot protocol
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatsize - determine a file’s size
fatwrite- write file into a dos filesystem
fdt - flattened device tree utility commands
fstype - Look up a filesystem type
go - start application at address ‘addr’
gpt - GUID Partition Table
help - print command description/usage
icache - enable or disable instruction cache
iomem - Show iomem data by device compatible
lcdputs - print string on video framebuffer
load - load binary file from a filesystem
loop - infinite loop on address range
md - memory display
mdio - MDIO utility commands
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mmc - MMC sub system
mmcinfo - display MMC info
mw - memory write (fill)
nfs - boot image via network using NFS protocol
nm - memory modify (constant address)
nvme - NVM Express sub-system
part - disk partition related commands
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
pxe - commands to get and boot from pxe files
rbrom - Perform RESET of the CPU
reset - Perform RESET of the CPU
rkimgtest- Test if storage media have rockchip image
rktest - Rockchip Board Module Test
rockchip_show_bmp- load and display bmp from resource partition
rockchip_show_logo- load and display log from resource partition
rockusb - Use the rockusb Protocol
run - run commands in an environment variable
save - save file to a filesystem
setcurs - set cursor position within screen
setenv - set environment variables
showvar - print local hushshell variables
source - run script from memory
sysboot - command to get and boot from syslinux files
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
usb - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
=> usbboot
** No device specified **
I also do not know English, and use a computer translator. :slight_smile:
Can you show the UART log when USB connected with the recorded system from the specified links ? Download, unzip, burn the image to a USB flash drive, connect to RockPI and turn on the power. No need to press any buttons. show the UART log.
I looked at the variables, to run all the media correctly (with the correct sequence), you need to make a few changes. Then u-boot in SPI will be able to start normally all systems from different carriers, without interfering with each other.
Radxa Team
You can throw me in lichku file with variables ENV from sources u-boot, which you are using for Assembly version of u-boot SPI ?
I am running into this issue, and the lack of progress from Radxa on making the Rock Pi 4B work with NVME is getting really bothersome.
