/dev/disk/by-uuid/35fbc645-a3ff-4851-9cba-98e3f13e7121 /home ext4 defaults 0 2
Hello, thanks for answering. Finally I have chosen to leave things as they are, and add an additional partition for downloads and files. I left the / home folder as it was.
Now I have a question regarding the average temperature. I donât know if this is the place to raise it, or if I should open a new post.
There was free time and I designed my previous work in the form of a script.
Now the program can be used not only to create new partitions, but also to modify existing ones
Download, unzip to folder /usr/local/sbin/ and install kpartx
tar -xzvf make_multiboot_dev.sh.tar.gz -C /usr/local/sbin/
sudo apt install kpartx
Example of creating a multi-boot microSD device with three OS. Change /dev/sdz to own and change sizes depending on your needs and drive sizes:
sudo su
#---- Make GPT and flash uboot
make_multiboot_dev.sh --device /dev/sdz --uboot-file rockpi4b-ubuntu-bionic-minimal-20190104_2101-gpt.img
#---- Flash 3 OS
make_multiboot_dev.sh --device /dev/sdz --boot-size 128 --image-file rockpi4b-ubuntu-bionic-minimal-20190104_2101-gpt.img
make_multiboot_dev.sh --device /dev/sdz --image-file Armbian_20.02.0-rc0_Rockpi-4b_bionic_legacy_4.4.210_desktop.img
make_multiboot_dev.sh --device /dev/sdz --boot-size 512 --root-size 2048 --image-file LibreELEC-ARM-ALL.arm-9.80-devel-20200331083128-569f834-rk3399.img
An example of how to write a boot partion on microSD, and root on SSD
make_multiboot_dev.sh --boot-dev /dev/mmcblk0 --root-dev /dev/nvme0n1 --image-file Armbian_20.02.0-rc0_Rockpi-4b_bionic_legacy_4.4.210_desktop.img
Devices must have free space at the end.
You can use existing partions. In this case, free space is not needed, but the data on these partions will be erased. for instance
make_multiboot_dev.sh --boot-device /dev/mmcblk0p7 --root-dev /dev/nvme0n1p5 --image-file LibreELEC-ARM-ALL.arm-9.80-devel-20200331083128-569f834-rk3399.img
You can create one partion, use the other from the old.
With the --help switch, the program gives a hint.
Can currently be used OS : debian and ubuntu from radxa, Armbian⌠and LibreELECâŚ
Actions after the first start of radxa ubuntu
default login: rock password: rock
Donât install rockchip-fstab !!!
sudo su
apt update && apt upgrade
apt install rockchip-overlay rockpi4b-rk-u-boot-latest rockpi4-dtbo # On the first question of confirmation of installation, press 'y', on the second question of the bootloader, press 'n' !!!
apt install ssh parted mc nano kpartx gdisk linux-base linux-4.4-latest
return_my_root_to_extlinux.sh
# check configs
cat /boot/extlinux/extlinux.conf
cat /etc/fstab
If ever a new kernel is installed during an apt upgrade, then always use return_my_root_to_extlinux.sh to restore the correct path to rootfs!
interesting. At the moment I am working with armbian multiboot from nvme image that you provided. I have the rockpi as a desktop right now. retire for a while the desktop pc. and i am buying an nvme / usb-A adapter to work with other nvme memory without resorting to the old pc. Until it reaches me from China, I will continue with what I have now. I hope it is not a problem to have only 4 gb free on roofts. I would like to try manjaro, but from the manjaro foro they tellme: https://forum.manjaro.org/t/manjaro-arm-20-04-released/133374/37?u=yuvia
everything that was written before this quote I did not quite understand.
I looked at the link ⌠he means that without SPI you can not load boot from nvme. If your NVME boots through SPI then there should be no problem.
I made a new version of the script. Now you can still install Manjaro and slarm64 images. The -v switch is added. When selected, the program version is displayed.
To install Manjaro on an SSD:
make_multiboot_dev.sh -d /dev/nvme0n1 --root-size 10000 -i Manjaro-ARM-xfce-rockpi4-20.04.img
Change root-size and image file as you need
Thank you very much for answering.
What I did was replace my old pc with rockpi4b with the Armbian multiboot image you provide above.
Iâll continue with this multiboot image for now because it works really well. The only thing that worries me is that the Armbiam system partition has 8gb of space of which 3gb is free. I have purchased a usb adapter to hot plug an additional nvme card into the rockpi4b box. But I still donât have it in my possession.
I will try to test your indications as soon as possible. Thank you
Hi. Excuse me for bothering you. I make a query. Is there a way to implement dtoverlay = pcie-gen2 in armbian from the image you provided above? I tried this by adding the line in /boot/armbianEnv.txt but I saw no difference in read / write speeds.
Env.txt not work here. Try adding dtoverlay=pcie-gen2 to the end of the APPEND line of extlinux.conf, but I donât know if this will work.
and what about this link ?: https://github.com/radxa/kernel/blob/release-4.4-rockpi4/arch/arm64/boot/dts/rockchip/overlays-rockpi4/pcie-gen2-overlay.dts
On radxa OS, this works if write intfc:dtoverlay=pcie-gen2 in the hw_intfc.conf file. I tested it. I did not test on armbian.
Hello, thanks for the information. Is there a way to restore the modified files without resorting to another machine in case the box doesnât boot after making those changes?
Thanks for your script and idea @rua1! ![]()
While writing uboot a warning is displayed:
Warning: The resulting partition is not properly aligned for best performance.
Should we fix it?
The u-boot I used is this one: https://dl.radxa.com/rockpi4/images/loader/spi/rockpi4b-uboot-trust-spi_2017.09-2681-geb41d9a6ce_20191104.img
Flashed it to eMMC drive (/dev/mmcblk2).
After writing slarm64 image, the extlinux.conf file looks like the following:
LABEL slarm64
LINUX /Image
FDT /dtb//tmp/1/dtb/rk3399-rock-pi-4.dtb
APPEND root=PARTUUID=bc91ac33-cba2-4a2a-ba9c-42a3b77145de rw rootwait console=ttyS2,1500000
The FDT part looks incorrect, corrected it to /dtb/rk3399-rock-pi-4.dtb
The resulting image does not boot for me though. Status LED does not blink, screen stays blank. Attached a serial console, but there is no output at all.
Attaching SD card and rebooting works, the system is booted from SD card.
Tested 2 images, Slarm64 and Radxa Debian Stretch, in both cases there is no output on serial console and system does not boot.
Thanks.
If you do not have another computer nearby, you need to prepare a separate microsd OS in advance for repair. In case of a loading error, insert the card into the microsd slot for repair, insert the card with the damaged OS into the card reader and then into the USB connector. Boot from microsd to repair and restore files on your usb.
I use a debug cable connected to another computer. In case of failure, I interrupt the boot process and manually load another OS.
You should not pay attention to this message. Iâll try to remove it.
This uboot is designed for SPI. write ubootl from radxa debian or ubuntu.
under what OS you this make?
I wrote u-boot from Radxa Debian image to eMMC, but it was incompatible with mbr partitions, and failed to boot Slarm64 or Armbian on SD card.
I have an install of Radxa Debian which is updated, will try to use u-boot from there.
I tried from 2 OS, Slarm64 and Armbian Debian buster. Both gave same result.
Thanks.
hm ..
LABEL slarm64
LINUX /Image
FDT /dtb/rk3399-rock-pi-4.dtb
uname -a
Linux rockpi-4b 5.4.28-rockchip64 #20.02.7 SMP PREEMPT Sat Mar 28 17:07:03 CET 2020 aarch64 GNU/Linux
Armbian_20.02.7_Rockpi-4b_buster_current_5.4.28_desktop
âŚ
what version of the script you use?
Script with Version 1.2c
With u-boot from updated Radxa Debian image, the serial console works. However it does not boot. Output:
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xef1e8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):0e7a845
NOTICE: BL31: Built : 16:13:46, Apr 17 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-2686-g18c70dba63 (Dec 31 2019 - 12:34:04 +0000), Build: jenkins-linux-build-testing-2-136
Model: Rockchip RK3399 rockpi4b Board
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bdf000
Sysmem: init
I2c speed: 400000Hz
PMIC: RK808
vdd-center init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
Bootdev(atags): mmc 0
PartType: EFI
get part misc fail -1
boot mode: None
init_resource_list: failed to get boot part, ret=-1
init_resource_list: failed to get resource part, ret=-1
Can't find file:logo.bmp
failed to display uboot logo
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'): 0
Device 0: unknown device
MMC: no card present
mmc_init: -123, time 0
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
** Unrecognized filesystem type **
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: failed to get usb phy
Port not available.
USB3: failed to get usb phy
Port not available.
USB4: Can't get the usbphy register address
probe failed, error -6
USB5: Can't get the usbphy register address
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
ethernet@fe300000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@fe300000
Retrieving file: pxelinux.cfg/01-ae-1e-19-20-55-6d
My mistake. While trying to update u-boot, looks like I made a typo and deleted the image partitions.
Here is the output while flashing Radxa Debian, one warning:
Size of image BOOT partition is 512 MiB
it flash into partition with size 512 MiB
Size of image ROOT partition is 3051 MiB
it flash into partition with size 8192 MiB
Type Y/y to continue or Ctrl-C to abort.
y
Work with partitions ...
Attention! If the program does not end with the phrase 'End Of Script' then manually do 'umount /tmp/{1..4}', 'rmdir /tmp/{1..4}'
and remove partions: /dev/mmcblk2p4 /dev/mmcblk2p5
Files are copied, wait ...
rm: cannot remove '/tmp/2/etc/FIRST_BOOT': No such file or directory
After flashing it worked, and was booted to the Radxa Debian image!
Thank you @rua1! ![]()
Will try with more images now.
Full output while flashing Slarm64:
# ../downloads/make_multiboot_dev.sh --device /dev/mmcblk2 --boot-size 1024 --root-size 10240 --image-file slarm64-current-aarch64-xfce-rootfs-14Dec19-5.4.6-rock_pi_4-build-20191222.img
Size of image ROOT partition is 5684 MiB
it flash into partition with size 10240 MiB
y
and remove partions: /dev/mmcblk2p6 /dev/mmcblk2p7
---------/boot/*Env.txt :
verbosity=4
console=both
fdtfile=rk3399-rock-pi-4.dtb
rootdev=/dev/mmcblk1p1
---------found RockPi4 fdt files :
--------- extlinux.conf :
LABEL slarm64
LINUX /Image
APPEND root=PARTUUID=75eed00b-3ffd-4562-9f40-e7e0d5f1557c rw rootwait console=ttyS2,1500000
---------- /etc/fstab :
# /etc/fstab: static file system information
# <file system> <mount point> <type> <options> <dump> <pass>
shm /dev/shm tmpfs defaults 0 0
devpts /dev/pts devpts noexec,nosuid,gid=tty,mode=0620 0 0
sysfs /sys sysfs defaults 0 0
proc /proc proc defaults 0 0
#/dev/#EXT4FS_BOOT# /boot ext4 errors=remount-ro 0 1
#/dev/#SWAP# swap swap defaults 0 0
#/dev/#EXT4FS_ROOT# / ext4 errors=remount-ro 0 1
#/dev/#EXT4FS_HOME# /home ext4 defaults 0 2
UUID=9f4441e4-07f0-4ee9-91ae-640ca1429c22 / ext4 noatime,nodiratime,data=writeback,errors=remount-ro 0 1
UUID=0629b095-d61d-4ba3-8676-adc896d2efd1 /boot ext2 defaults 0 0
loop deleted : /dev/loop0
-= All OK =-
-= End Of Script =-
This one also booted.
However there was no console output on tty1, so I made some changes to extlinux.conf based on studying boot.scr.bak:
# APPEND root=PARTUUID=75eed00b-3ffd-4562-9f40-e7e0d5f1557c rw rootwait console=ttyS2,1500000
APPEND root=PARTUUID=c1f2eb7f-064b-40e4-9826-c174658e065e ro rootwait console=ttyS2,1500000 consoleblank=0 earlyprintk console=tty1 loglevel=4
Comment part is before, uncommented part is after.
Also changed rw to ro since Slarm64 uses it for checking the partition and then remounts it after check.
@rua1, maybe you could upload your script to gitlab? Can send you pull request there!
Thanks again for your work. ![]()
@aaditya Thanks a lot for testing! I apologize for not posting announcements of new versions here. did not see much interest from other people. Now version 1.3 is located on the same link, maybe with it you will not have an error /dtb//tmp/1 âŚ
[quote = âaaditya, post: 39, topic: 2838â]
rm: cannot remove â/ tmp / 2 / etc / FIRST_BOOTâ: No such file or directory
[/quote]
Thanks again, I had to check in the script for the file first;). I was mistaken in the fact that all radxa OSs are built in the same way. I tested mainly on ubuntu.
In some OSs I got rid of the system extension to the entire disk (ubuntu, manjaro,
slarm, LibreELEC).
[quote = âaaditya, post: 40, topic: 2838â]
[/quote]
I will try to make these changes in the script ⌠but ⌠in the latest versions of the script the option âextlinux-conf-file where you can put the âskeletonâ of a file suitable for you. You can share these files in this thread ![]()
[/quote]
The idea is very good, but I need to study this technology, then there may not be time left to work on the script itself;)
