KingSpec 128GB M.2 NVMe not found Debian+Ubuntu
Hi. Today my KingSpec 128GB M.2 NVMe SSD arrived.
I connected it, but have no luck finding it.
Step 1 as super user : ls /dev/nvme*
gives
ls: cannot access ’ /dev/nvme* ’ : No such file or directory
This in both Debian and Ubuntu.
I’ve checked the /dev/ directory, and there is no nvme file there.
I keep the drive straight with the weight of the RockPi itself like this. It doesn’t look pretty. But it should work.
Any help is welcome. Thank you.
NicoD
The PCIE on rk3399 doesn’t support hot plug. Make sure you plug NVMe ssd first then power up.
I did plug it in while the power was off. Then turned it on, and … nothing.
Would it be not compatible? Or could it be a driver problem or so?
I`ve tried many times with Ubuntu and Debian.
My pc doesn`t support nvme so I have no other way to check the drive.
Hi, Nico
I am afraid it’s the SSD issue…
We have bought two Kingspec 1T NVMe for the desktop since it has the best performance/price ratio so far. The first one works fine. The second was not recognized on PC or ROCK Pi 4. Then we replaced the second one to a third new one. The third one is recognized, but formatting takes forever, ROCK Pi 4 can detect it and dd read/write seems ok, but creating any filesystem just hang there. Returned it now.
Btw, working with NVMe, you need something like this…
NVMe to USB3.1 reader.
Thank you for your answer. Good it wasnt too expensive. I dont really need it, it was just for a video about different storage media. I still got USB memory stick, SD-cards, eMMC,and SATA ssd`s over USB3.
I`ll advice to buy the tested nvme models in my review. Thank you.
Not sure I would advise to buy the tested NVME’s. 2 of three failed.
what brand and models have you tried? Could you list here, it might helps others.
Sorry I was not clear. I was referring to the ones you guys tested. 2 of your 3 failed to perform correctly.
I am interested in using NVMe on the RockPi4B.
  1. Can we boot from it?
  2. If we cant boot from it can you provide instructions to create a boot mSD or EMMC and have the file system on the NVMe?
  3. Is there some type of HAT or adapter board to secure it in place?
I meant the ones that are tested and found ok. But the KingSpec is still in the list.
- Known working -
  • Samsung EVO series( M key, NVMe ), work well on ROCK Pi 4, fast speed
  • KingSpec NVMe M.2 2280( M key, NVMe ), works well
  • MaxMemory NVMe M.2 128G( B&M key, NVMe ), works well
- Known not working -
  • HP EX900( B&M Key, NVMe ), detection failed on ROCK Pi 4, works with PC.
I tried the KingSpec128GB in Armbian and also no luck.
@TheDude Q3 :
“We have made a M.2 extended board to put the M.2 SSD on top of ROCK Pi4. It looks like this. See picture here and here.”
https://wiki.radxa.com/Rockpi4/FAQs
Thanks. I knew I saw something like that somewhere.
Allnet China is out of stock and the austria & german sites wont let me register to purchase.
I was also looking at that big heatsink too but its also out of stock. Where else can I purchase?
The big heatsink will start shipping after next Wednesday.
I bay GoodRAM 120GB m2 2280 and on Armbian image not working. Is m2 included in armbans kernel?
Samsung EVO 970 NVME M.2 250GB installed and seems to be working good. $77 delivered.
Booting from MicroSD and filesystem on NVME
FULL WRITE PASS
writefile: (g=0): rw=write, bs=(R) 4096KiB-4096KiB, (W) 4096KiB-4096KiB, (T) 4096KiB-4096KiB, ioengine=libaio, iodepth=200
fio-3.1
Starting 1 process
Jobs: 1 (f=0): [f(1)][100.0%][r=0KiB/s,w=1468MiB/s][r=0,w=367 IOPS][eta 00m:00s]
writefile: (groupid=0, jobs=1): err= 0: pid=2343: Sat Dec 22 16:03:24 2018
  write: IOPS=198, BW=792MiB/s (831MB/s)(10.0GiB/12923msec)
    slat (usec): min=719, max=8530, avg=2995.68, stdev=847.41
    clat (msec): min=78, max=1076, avg=970.65, stdev=140.19
     lat (msec): min=80, max=1079, avg=973.65, stdev=140.15
    clat percentiles (msec):
     |  1.00th=[  203],  5.00th=[  718], 10.00th=[  995], 20.00th=[ 1003],
     | 30.00th=[ 1003], 40.00th=[ 1003], 50.00th=[ 1003], 60.00th=[ 1003],
     | 70.00th=[ 1003], 80.00th=[ 1003], 90.00th=[ 1011], 95.00th=[ 1011],
     | 99.00th=[ 1020], 99.50th=[ 1028], 99.90th=[ 1070], 99.95th=[ 1070],
     | 99.99th=[ 1083]
   bw (  KiB/s): min=114688, max=825675, per=96.36%, avg=781855.67, stdev=142262.46, samples=24
   iops        : min=   28, max=  201, avg=190.83, stdev=34.72, samples=24
  lat (msec)   : 100=0.20%, 250=1.17%, 500=1.91%, 750=1.95%, 1000=10.82%
  lat (msec)   : 2000=83.95%
  cpu          : usr=39.53%, sys=13.87%, ctx=3292, majf=0, minf=22
  IO depths    : 1=0.1%, 2=0.1%, 4=0.2%, 8=0.3%, 16=0.6%, 32=1.2%, >=64=97.5%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.1%
     issued rwt: total=0,2560,0, short=0,0,0, dropped=0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=200
Run status group 0 (all jobs):
  WRITE: bw=792MiB/s (831MB/s), 792MiB/s-792MiB/s (831MB/s-831MB/s), io=10.0GiB (10.7GB), run=12923-12923msec
Disk stats (read/write):
  nvme0n1: ios=24/10340, merge=0/0, ticks=80/813176, in_queue=813520, util=90.69%
RAND READ PASS
benchmark: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=128
fio-3.1
Starting 4 processes
Jobs: 4 (f=4): [r(4)][100.0%][r=664MiB/s,w=0KiB/s][r=170k,w=0 IOPS][eta 00m:00s]
benchmark: (groupid=0, jobs=4): err= 0: pid=2388: Sat Dec 22 16:03:55 2018
   read: IOPS=167k, BW=653MiB/s (685MB/s)(19.1GiB/30001msec)
    slat (usec): min=6, max=28457, avg=13.17, stdev=41.48
    clat (usec): min=67, max=44178, avg=3041.52, stdev=1214.98
     lat (usec): min=82, max=44203, avg=3055.53, stdev=1216.38
    clat percentiles (usec):
     |  1.00th=[ 1975],  5.00th=[ 2073], 10.00th=[ 2147], 20.00th=[ 2278],
     | 30.00th=[ 2507], 40.00th=[ 2769], 50.00th=[ 2900], 60.00th=[ 3097],
     | 70.00th=[ 3195], 80.00th=[ 3261], 90.00th=[ 3458], 95.00th=[ 4817],
     | 99.00th=[ 8717], 99.50th=[10159], 99.90th=[12780], 99.95th=[15533],
     | 99.99th=[28181]
   bw (  KiB/s): min=97653, max=205186, per=25.15%, avg=168204.46, stdev=13527.72, samples=239
   iops        : min=24413, max=51296, avg=42050.92, stdev=3381.90, samples=239
  lat (usec)   : 100=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01%
  lat (msec)   : 2=1.91%, 4=91.08%, 10=6.44%, 20=0.52%, 50=0.02%
  cpu          : usr=28.59%, sys=58.64%, ctx=238159, majf=0, minf=580
  IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%
     issued rwt: total=5017168,0,0, short=0,0,0, dropped=0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=128
   READ: bw=653MiB/s (685MB/s), 653MiB/s-653MiB/s (685MB/s-685MB/s), io=19.1GiB (20.6GB), run=30001-30001msec
  nvme0n1: ios=4993296/151, merge=0/0, ticks=7113608/20, in_queue=7271444, util=100.00%
RAND WRITE PASS
benchmark: (g=0): rw=randwrite, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=128
fio-3.1
Jobs: 4 (f=4): [w(4)][100.0%][r=0KiB/s,w=309MiB/s][r=0,w=78.0k IOPS][eta 00m:00s]
benchmark: (groupid=0, jobs=4): err= 0: pid=2397: Sat Dec 22 16:04:26 2018
  write: IOPS=141k, BW=550MiB/s (576MB/s)(16.1GiB/30007msec)
    slat (usec): min=7, max=29844, avg=15.78, stdev=39.77
    clat (usec): min=155, max=58346, avg=3615.78, stdev=1959.79
     lat (usec): min=200, max=58356, avg=3632.55, stdev=1963.67
     |  1.00th=[ 2212],  5.00th=[ 2212], 10.00th=[ 2245], 20.00th=[ 2245],
     | 30.00th=[ 2245], 40.00th=[ 2278], 50.00th=[ 3359], 60.00th=[ 3425],
     | 70.00th=[ 3458], 80.00th=[ 5669], 90.00th=[ 6521], 95.00th=[ 6915],
     | 99.00th=[ 7767], 99.50th=[ 8717], 99.90th=[18744], 99.95th=[32637],
     | 99.99th=[45351]
   bw (  KiB/s): min=72848, max=228256, per=25.06%, avg=141069.82, stdev=58131.44, samples=239
   iops        : min=18212, max=57064, avg=35267.34, stdev=14532.85, samples=239
  lat (usec)   : 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01%
  lat (msec)   : 2=0.04%, 4=76.87%, 10=22.70%, 20=0.30%, 50=0.07%
  lat (msec)   : 100=0.01%
  cpu          : usr=29.55%, sys=56.29%, ctx=50270, majf=0, minf=73
     issued rwt: total=0,4222617,0, short=0,0,0, dropped=0,0,0
  WRITE: bw=550MiB/s (576MB/s), 550MiB/s-550MiB/s (576MB/s-576MB/s), io=16.1GiB (17.3GB), run=30007-30007msec
  nvme0n1: ios=49/4212455, merge=0/0, ticks=164/5898416, in_queue=6182236, util=100.00%
By default, the nvme is running at gen1 mode for compatibility, so the speed is limited. You can enabled gen2 mode by decompile and recompile the device tree:
fdtdump rockpi-4b-linux.dtb  > /tmp/rockpi4.dts
Find pcie@f8000000 section
change from
max-link-speed = <0x00000001>;
to
max-link-speed = <0x00000002>;
Now recompile the dtb:
dtc -I dts -O dtb /tmp/rockpi4.dts -o /tmp/rockpi4.dtb
Replace the original rockpi-4b-linux.dtb(backup it first), reboot.
Thanks Jack
Thats a pretty big increase.
FULL WRITE PASS
fio-3.1
Starting 1 process
writefile: Laying out IO file (1 file / 10240MiB)
Jobs: 1 (f=1): [W(1)][88.9%][r=0KiB/s,w=1390MiB/s][r=0,w=347 IOPS][eta 00m:01s]
writefile: (groupid=0, jobs=1): err= 0: pid=1777: Mon Dec 24 16:43:26 2018
  write: IOPS=346, BW=1384MiB/s (1452MB/s)(10.0GiB/7397msec)
    slat (usec): min=955, max=36941, avg=1049.63, stdev=733.97
    clat (msec): min=6, max=613, avg=551.03, stdev=89.82
     lat (msec): min=7, max=614, avg=552.08, stdev=89.83
     |  1.00th=[   79],  5.00th=[  368], 10.00th=[  558], 20.00th=[  567],
     | 30.00th=[  567], 40.00th=[  567], 50.00th=[  567], 60.00th=[  575],
     | 70.00th=[  575], 80.00th=[  575], 90.00th=[  584], 95.00th=[  609],
     | 99.00th=[  617], 99.50th=[  617], 99.90th=[  617], 99.95th=[  617],
     | 99.99th=[  617]
   bw (  MiB/s): min= 1194, max= 1426, per=99.10%, avg=1371.84, stdev=64.89, samples=13
   iops        : min=  298, max=  356, avg=342.69, stdev=16.30, samples=13
  lat (msec)   : 10=0.08%, 20=0.12%, 50=0.43%, 100=0.66%, 250=2.07%
  lat (msec)   : 500=3.44%, 750=93.20%
  cpu          : usr=56.41%, sys=32.29%, ctx=2551, majf=0, minf=21
  WRITE: bw=1384MiB/s (1452MB/s), 1384MiB/s-1384MiB/s (1452MB/s-1452MB/s), io=10.0GiB (10.7GB), run=7397-7397msec
  nvme0n1: ios=0/10367, merge=0/0, ticks=0/84952, in_queue=84948, util=85.55%
RAND READ PASS
benchmark: (g=0): rw=randread, bs=(R) 32.0KiB-32.0KiB, (W) 32.0KiB-32.0KiB, (T) 32.0KiB-32.0KiB, ioengine=libaio, iodepth=128
fio-3.1
Jobs: 4 (f=4): [r(4)][100.0%][r=967MiB/s,w=0KiB/s][r=30.9k,w=0 IOPS][eta 00m:00s]
benchmark: (groupid=0, jobs=4): err= 0: pid=1792: Mon Dec 24 16:43:57 2018
   read: IOPS=30.2k, BW=944MiB/s (990MB/s)(27.7GiB/30002msec)
    slat (usec): min=15, max=9778, avg=125.19, stdev=100.40
    clat (usec): min=301, max=37557, avg=16798.40, stdev=2704.00
     lat (usec): min=355, max=37832, avg=16924.36, stdev=2722.99
     |  1.00th=[11338],  5.00th=[12387], 10.00th=[13435], 20.00th=[14353],
     | 30.00th=[15008], 40.00th=[15795], 50.00th=[16909], 60.00th=[17957],
     | 70.00th=[18482], 80.00th=[19006], 90.00th=[20055], 95.00th=[20841],
     | 99.00th=[23725], 99.50th=[25035], 99.90th=[26870], 99.95th=[27395],
     | 99.99th=[28967]
   bw (  KiB/s): min=172544, max=304578, per=25.02%, avg=241929.63, stdev=25099.97, samples=240
   iops        : min= 5392, max= 9518, avg=7560.12, stdev=784.36, samples=240
  lat (usec)   : 500=0.01%, 750=0.01%, 1000=0.01%
  lat (msec)   : 2=0.01%, 4=0.01%, 10=0.07%, 20=90.32%, 50=9.60%
  cpu          : usr=4.86%, sys=30.53%, ctx=771047, majf=0, minf=4169
     issued rwt: total=906608,0,0, short=0,0,0, dropped=0,0,0
   READ: bw=944MiB/s (990MB/s), 944MiB/s-944MiB/s (990MB/s-990MB/s), io=27.7GiB (29.7GB), run=30002-30002msec
  nvme0n1: ios=903426/235, merge=0/0, ticks=980104/188, in_queue=990116, util=100.00%
RAND WRITE PASS
benchmark: (g=0): rw=randwrite, bs=(R) 32.0KiB-32.0KiB, (W) 32.0KiB-32.0KiB, (T) 32.0KiB-32.0KiB, ioengine=libaio, iodepth=128
fio-3.1
Jobs: 4 (f=4): [w(4)][100.0%][r=0KiB/s,w=317MiB/s][r=0,w=10.2k IOPS][eta 00m:00s]
benchmark: (groupid=0, jobs=4): err= 0: pid=1800: Mon Dec 24 16:44:28 2018
  write: IOPS=20.6k, BW=643MiB/s (674MB/s)(18.8GiB/30005msec)
    slat (usec): min=19, max=45426, avg=186.90, stdev=394.09
    clat (msec): min=2, max=105, avg=24.69, stdev=19.49
     lat (msec): min=3, max=106, avg=24.88, stdev=19.64
     |  1.00th=[ 8291],  5.00th=[ 8848], 10.00th=[ 9110], 20.00th=[ 9503],
     | 30.00th=[10159], 40.00th=[12125], 50.00th=[12911], 60.00th=[13960],
     | 70.00th=[41681], 80.00th=[49021], 90.00th=[55837], 95.00th=[58459],
     | 99.00th=[63701], 99.50th=[70779], 99.90th=[85459], 99.95th=[89654],
     | 99.99th=[96994]
   bw (  KiB/s): min=68369, max=447353, per=25.06%, avg=164956.83, stdev=132069.05, samples=240
   iops        : min= 2136, max=13979, avg=5154.59, stdev=4127.13, samples=240
  lat (msec)   : 4=0.01%, 10=28.40%, 20=37.59%, 50=15.06%, 100=18.96%
  lat (msec)   : 250=0.01%
  cpu          : usr=6.27%, sys=19.83%, ctx=479319, majf=0, minf=82
     issued rwt: total=0,617292,0, short=0,0,0, dropped=0,0,0
  WRITE: bw=643MiB/s (674MB/s), 643MiB/s-643MiB/s (674MB/s-674MB/s), io=18.8GiB (20.2GB), run=30005-30005msec
  nvme0n1: ios=0/615562, merge=0/0, ticks=0/985784, in_queue=987744, util=100.00%
Hi @jack
witch one do i decompile, I found 4 files.
/usr/lib/linux-image-4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb
/media/rock/ubt-bionic/usr/lib/linux-image-4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb
/boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb
/boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb.dpkg-tmp
Thanks
Pierre
I guess this is the one:
This should be a backup from a previous version that was created before an update:
I have created a script to Do this. Mayby we can Put Together a serier of them and create a RocKpiConfig(A want to be raspiconfig) Please feel free to Improve the script. It Need Some Love.
#!/bin/bash
#By default, the nvme is running at gen1 mode for compatibility, so the speed is limited.
#You can enabled gen2 mode by decompile and recompile the device tree:
sudo cp -p /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb.bak
sudo fdtdump /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb > /tmp/rockpi4.dts
sudo sed -i ‘s/max-link-speed = <0x00000001>;/max-link-speed = <0x00000002>;/g’ /tmp/rockpi4.dts
#Find pcie@f8000000 section
#change from
#max-link-speed = <0x00000001>;
#to
#max-link-speed = <0x00000002>;
#Now recompile the dtb:
sudo dtc -I dts -O dtb /tmp/rockpi4.dts -o /tmp/rockpi4.dtb
sudo mv /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb.tmp
sudo cp /tmp/rockpi4.dtb /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb
ls -l /boot/dtbs/4.4.154-59-rockchip-g5e70f14/rockchip/rockpi-4b-linux.dtb
#Replace the original rockpi-4b-linux.dtb(backup it first), reboot.
What NVMe SSDs are recommended?
I think I’m going to order the large heatsink and the SSD extender (I should have ordered them when I got my rock pi4b but I wanted to test the SBC out a bit first)
Is there a list where I can see which ones are compatible, I don’t want to order one that isn’t compatible.
